ᐅ How can the IKEA Brimnes surface be protected after assembly?
Created on: 16 May 2019 08:45
FLOYAEL
Hello everyone, I recently assembled my new IKEA Brimnes furniture and am now wondering how to best protect the surface to keep it looking like new for as long as possible. I am especially interested in methods or products that help prevent scratches, minor wear, and general abrasion without negatively affecting the appearance or feel. Are there any home remedies or specialized care products you would recommend? I would also like to know if sealing with a specific type of varnish or wax is advisable and how these should be applied. I look forward to your experiences and tips!
Taubi
16 May 2019 11:23
I use a product called "Spraywax" on melamine-coated furniture. It forms a thin protective layer that guards the surface against scratches without becoming sticky.
Garthre
16 May 2019 11:55
Important to know: Melamine surfaces are very dense and resistant to water and common cleaning agents. An additional coating is usually counterproductive. Instead, I recommend: - Using well-known care products for laminate or melamine - Avoiding contact with sharp or rough objects in daily use - Regularly wiping with a soft microfiber cloth - Not using abrasive cleaners.
Deandre
16 May 2019 12:20
CORYGAU schrieb:
Personally, I believe the best care is regular, gentle cleaning combined with protection using covers or felt pads.
I completely agree. Additional sealing on melamine can do more harm than good. It also makes it easier to remove fingerprints and dust.
FLOYAEL
16 May 2019 14:07
Thank you for your assessments! This makes it clear that sealing might actually be more of a disadvantage. However, I wonder if there is any special care required for the Brimnes fronts (cabinet doors), since they come into contact with surfaces more frequently when being opened. Are felt pads sufficient, or is a special treatment recommended to protect against fine scratches from rings or nails?
RonJarrett
16 May 2019 14:25
FLOYAEL schrieb:
Is there any special care required for the Brimnes fronts (cabinet doors), since the surface is frequently touched when opening?
For doors specifically, I recommend soft rubber buffers at the edges to cushion impacts. Scratches mostly occur due to rings or dirt trapped under the nails. Cleaning your hands before contact can also help. An additional protective film is possible, but usually not preferred for aesthetic reasons.
Alice
16 May 2019 14:44
You can also use self-adhesive transparent protective films. They offer better protection against scratches but are only practical if you accept the visual compromise.
