Hello everyone, I recently bought an Ikea Brimnes bed and now I’m facing the challenge of how to secure the back panel of the bed frame in a really stable and long-lasting way. The included screws seem quite weak, and I’m concerned that the back panel won’t be properly supported over time. Does anyone have experience with additional fastening options or alternatives to firmly fix the back panel? I’m especially interested in mechanical solutions that are easy to implement and significantly increase the stability of the furniture without damaging it. I look forward to your tips and experiences!
Tomli schrieb:
Does anyone have experience with whether standard metal brackets can be used, or if special, perhaps flatter brackets from a hardware store are better?Standard metal brackets from a hardware store work well as long as they are not too thick. There are also so-called flat brackets that, due to their lower profile, fit better without bulking out the piece of furniture. I would recommend using a narrow, flat bracket to keep the surface as flush as possible and secure the back panel without gaps.
The screws should penetrate at least 20-25 mm (about 1 inch) into the framing timber to ensure a secure hold. The total length depends on the material thickness and the bead height. When in doubt, it is better to choose a slightly shorter screw to avoid drilling through. Precise pre-drilling is essential for thin boards.
