ᐅ How can the Ikea BRIMNES back panel be securely fastened?
Created on: 4 Aug 2019 08:17
Tomli
Hello everyone, I recently bought an Ikea Brimnes bed and now I’m facing the challenge of how to secure the back panel of the bed frame in a really stable and long-lasting way. The included screws seem quite weak, and I’m concerned that the back panel won’t be properly supported over time. Does anyone have experience with additional fastening options or alternatives to firmly fix the back panel? I’m especially interested in mechanical solutions that are easy to implement and significantly increase the stability of the furniture without damaging it. I look forward to your tips and experiences!
Traman4
5 Aug 2019 07:22
Wood glue is hardly effective for this back panel. Screws and brackets are the key.
NENAU
5 Aug 2019 07:53
That's right, wood glue doesn't work with such thin back panel material unless you want to glue the entire back panel completely – but that is not a common approach.
Jonna
5 Aug 2019 10:02
One more detail: Make sure the screws are not too long to prevent them from protruding on the front side. Also, when positioning the brackets, choose locations that will not interfere with the bed assembly. The brackets should be made of corrosion-resistant material to ensure durability.
V
vinpau
5 Aug 2019 11:20
Yes, I think that is very important! I used stainless steel brackets, definitely a great choice! They last forever, you can’t really see them, but you don’t have to keep thinking about it either.
meGreg
5 Aug 2019 18:35
Haha, I really like the DIY charm of Ikea furniture. You buy everything nicely pre-assembled, and then you stabilize it yourself! For me, that meant screws, brackets, and a custom frame. For anyone who still enjoys tinkering: grab your screwdriver and go for it! 😜
Tomli
6 Aug 2019 08:39
Thanks for all the tips so far! If I understand correctly, additional screws, brackets, and wooden battens are the most important measures.
I'm also interested to know: Does anyone have experience with using standard furniture brackets, or are special, perhaps flatter brackets from the hardware store better suited? When installing, the back panel needs to fit as closely as possible against the frame to avoid any play.
