ᐅ How can the height of Ikea PAX wardrobes be adjusted flexibly?
Created on: 26 Mar 2024 09:13
ixleo56
I have a question regarding the adjustable shelf heights in the Ikea Pax systems: How can the height of individual compartments be made as flexible as possible to accommodate different needs? My goal is to maximize the available storage space and to easily store both tall and short items. Are there any proven methods or special accessories suitable for this purpose? Additionally, I am interested in whether shelf boards can be adjusted to intermediate heights without much effort, as I have not yet found clear solutions for this. I look forward to concrete tips and experiences!
Wesley
27 Mar 2024 14:56
kulau schrieb:
The inner sides consist of rows of holes spaced 32 mm (about 1.25 inches) apart, which is a standard grid in furniture construction, allowing shelf supports to be inserted.
That’s exactly the point, and the 32 mm spacing can be used very flexibly!
Here’s a small practical tip: For those narrow gaps that can’t be filled with the original shelves, try looking for thin plywood at the hardware store, about 4-6 mm (0.15–0.25 inches) thick. It’s easy to cut to size—this way you can create height adjustments in millimeters.
If you’re a bit experimental, flexible hangers like clamp profiles that attach to the holes can also be used, making the shelf height even more adaptable.
This way, you can build your shelves almost like a modular system, customized for any use. It’s fun and looks great in the end!
U
usbla
28 Mar 2024 07:35
The height flexibility of Ikea Pax shelves is ensured by the standard drilling in a 32-mm (1.26-inch) grid. Practically, this means:
- The shelves can be adjusted in 32-mm (1.26-inch) increments.
- For more precise height adjustments, thin intermediate shelves made of plywood or multiplex panels are recommended.
- It should be noted that the maximum load capacity of Ikea shelves usually ranges between 15 and 25 kg (33 and 55 lbs).
- When planning shelf heights, the thickness of the shelves themselves must also be taken into account.
Additionally, Ikea offers supplementary accessories such as drawers or baskets to optimize vertical space usage.
Conclusion: Flexibility is provided by the grid system, and the targeted use of additional thin intermediate shelves increases adjustable options.
bauku
28 Mar 2024 14:22
Wow, the Pax system really offers fantastic options for flexible height adjustment! 😍 Especially if you want to store different items, the 32 mm (1.25 inch) hole spacing is almost a blessing.
I would casually recommend planning a mix of fixed shelves and removable elements in each compartment.
- Make sure to include baskets or drawers that you can reposition.
- Small rearrangements make the shelving dynamic and functional!
Also: Don’t be discouraged by the construction method. Even if the spacing seems fixed, with a bit of creativity you can get more out of it than you think!
Good luck – there’s a lot of potential here! 😉
