ᐅ How can the doors of the Pax wardrobe be customized with color?
Created on: 12 Nov 2021 08:37
remigla
remigla
12 Nov 2021 08:37
I am planning to customize the color of my PAX wardrobe and am looking for practical ways to personalize and permanently enhance the doors. It is important to me that the surface is not only visually appealing but also durable against everyday wear and tear. I am especially interested in the following points:
- Which materials are best suited for coloring the PAX doors?
- Are there proven techniques for painting or applying adhesive coverings to the doors without impairing their functionality?
- What about surface preparation; is sanding or priming necessary?
- Which tools and paints are recommended to ensure the result is both attractive and long-lasting?
If anyone has personal experience with recoloring a PAX wardrobe, I would greatly appreciate detailed tips and advice. Also, any potential pitfalls or care instructions would be very helpful.
Thanks in advance!
bapar
12 Nov 2021 14:52
Hello remigla,
Regarding your question about how to color the doors of the PAX wardrobe, I’d like to give you some detailed tips that should help you successfully complete the project.
First of all, it’s important to know that the doors are usually made of coated wood-based panels. Therefore, you should thoroughly prepare the surface before painting. This means:
- Clean the door surfaces with a grease-removing cleaner to remove all residues.
- Sanding is essential. Use very fine sandpaper (grit 220 to 320) to roughen the existing paint or coating so the new paint can adhere better.
- After sanding, wipe the surface with a dry cloth to remove dust.
Next, I recommend using a primer specifically designed for smooth or coated surfaces. This not only improves paint adhesion but also blocks discoloration.
For the paint, you can choose between different options:
- Water-based acrylic paint is recommended because it has low odor and dries relatively quickly.
- Alkyd enamel paints are more durable and suitable for doors but have a higher environmental impact.
- Alternatively, special spray or roll-on furniture paints are also options.
In terms of tools, high-quality brushes with fine bristles or foam rollers work best to achieve an even finish.
Important: Apply several thin coats and allow each one to dry thoroughly to avoid blistering.
As an alternative to painting, you can also use films or special self-adhesive furniture foils. These are easy to apply and replaceable if needed, but you should choose quality products to avoid bubbles or peeling.
Finally, seal the surface with a clear varnish (matte or satin finish) to protect the color.
Do you already have a specific color tone or style in mind, or are you looking for something subtle or more striking?
Ellis
12 Nov 2021 16:19
bapar schrieb:
Finally, it should be said: Seal the surface with a clear varnish (matte or satin matte) to protect the paint.
Exactly, this is an important step. Additionally, I recommend sanding the doors beforehand and applying a primer. Otherwise, the paint will not adhere well.
naujon
13 Nov 2021 09:45
remigla schrieb:
Which materials are best suited for painting PAX doors?
I’d like to follow up and offer you a simple step-by-step guide on how to proceed:
1. Remove the doors: To work comfortably, carefully take the doors off their hinges.
2. Cleaning: Remove grease and dirt using isopropanol or a mild dish soap.
3. Sanding: As mentioned before, lightly sand the surface with fine-grit sandpaper to improve adhesion.
4. Apply primer: An acrylic-based adhesion primer usually works best.
5. Choosing the paint:
- For a smooth, matte finish, RAL or acrylic paint is ideal.
- For a special effect, you can also use chalk paint, but keep in mind that the surface will need to be sealed afterward.
6. Painting: Apply several thin layers, allowing each to dry well; lightly sand between coats.
7. Sealing: Use a clear coat to protect against scratches and moisture.
Ellis schrieb:
Exactly, that’s an important step.
Finally: Work in well-ventilated spaces and take your time for precision. Small mistakes can be corrected with water or fine sandpaper.
If you want an even more personalized look, you can also cover the doors with furniture film, which is especially useful for patterned or textured films. However, surface preparation is just as important here to ensure the film does not peel off prematurely.
