ᐅ How can you prevent screws from pulling out of Billy-style shelves?
Created on: 19 Oct 2016 20:07
JokunauHello everyone,
I recently assembled a few Billy shelves from Ikea, but after a short time, I noticed that some screws are starting to pull out of their holes, especially in areas where the shelves bear more weight. My question is: what is the best way to prevent the screws from pulling out in Billy shelves? Are there specific techniques or materials that can be used to improve stability and extend the lifespan of the joints?
I have considered whether pre-drilling or using dowels might help, or if using different screws would be better. Who has experience with this or can provide informed advice? Thanks in advance!
Hello Jokunau,
great that you asked your question so precisely, that really helps a lot! Regarding your problem with the Billy shelves and the screws pulling out, there are actually several approaches which I will explain step by step:
1. Screw quality and drill holes: Billy shelves usually use smaller chipboard screws that are driven into pre-made holes. If the screws are too long or the hole diameter doesn’t fit exactly, the hold deteriorates. I always recommend drilling the holes slightly smaller than the screw diameter first. This protects the material and helps the threads hold better.
2. Reinforcement with dowels or barrel nuts: If the hole is already “frayed,” cross dowels or metal barrel nuts combined with the right screws can help. This increases the bearing surface and distributes the load better.
3. Use of wood glue: Sometimes you can strengthen the thread by applying a drop of wood glue or wood filler before inserting the screw. A slight excess is fine since it can be sanded down later. However, the glue should not be too runny to avoid everything sticking together unintentionally.
4. Check material quality: Billy shelves are made from chipboard, which unfortunately isn’t very strong. If you hang heavy loads, screw pull-out can be a weak point. It can help to avoid screwing directly into the back panel and instead use the sides, where there is more material thickness.
5. Load distribution and mounting: Also, make sure not to apply point loads to the shelves but distribute the weight as evenly as possible. Additionally, mounting with corner brackets can reinforce the structure.
I’m curious about how heavy the load is in your case? Did you fasten the shelf to the wall or is it freestanding?
Jokunau schrieb:That is a very good question, often this topic is underestimated. Stability in furniture construction always depends on several factors: material, joint technique, and load profile. I can give you more specific tips if you describe your application scenario in more detail.
Are there special techniques or materials that can be used to improve stability and increase the lifespan of the joint?
Hey Jokunau and everyone else!
It’s great that you’re diving so deep into this topic!!! 🙂 Stripped screws are really annoying, but with a few tricks, you can easily prevent it!
I used to install my Billy shelves with so-called ‘Spax screws’ – they’re a bit more expensive than the standard Ikea screws but have great grip! Also, I always use wood glue, not too much, just a small drop before screwing in, and then the screws hold really firmly!
Another helpful tip is to put a protective layer under the screw, like a small wooden washer or a flat washer, to better distribute the load!
And very important: don’t screw too tightly, otherwise the chipboard will crack, and everything is ruined. It’s better to screw in carefully and with some feel!
Keep us updated on how it goes for you! Good luck 😉
Short answer: Do not screw directly into the particleboard with too much force; pre-drilling is helpful. For load-bearing applications, always reinforce additionally with angle brackets. If screws are already causing damage, it is better to choose larger or different fasteners.
fidasi schrieb:
Use wood glue or wood filler to reinforce before inserting the screwI really like this tip because with just a little effort, you can often save a lot!
Also, keep in mind that Billy shelves have their limits. The design wasn’t originally made for heavy loads – a bit of gentle handling and evenly distributing the weight are essential :-)
If you occasionally tighten the screws with a screwdriver, you can avoid loose spots. And if you want to go further: using small wooden washers can effectively “enlarge” the screws and prevent them from slipping out.
Stay relaxed and experiment a bit – in the end, it’s also fun to see how simple tricks can turn a Billy into a real powerhouse 😉
