ᐅ How can you prevent damage to the back panels of Ikea Brimnes furniture?
Created on: 5 Jul 2022 09:18
Nibael
Nibael
5 Jul 2022 09:18
Hello everyone, I recently bought some Ikea Brimnes furniture and noticed that the backs of these pieces are quite delicate and can be easily damaged, whether during assembly, transport, or later when mounted on the wall. My specific question is: how can one prevent damage to the back panels of Ikea Brimnes furniture? I am especially interested in which protective measures can be taken before assembly, which tools or materials are useful, and how to securely fix the furniture to the wall without damaging the back panel. I would also appreciate tips on proper handling during transport or recommendations for protective films or similar solutions. Thanks in advance for your help!
kulau
5 Jul 2022 11:47
Hello Nibael, your question is very well formulated and addresses a common issue with Ikea Brimnes furniture. The back panels are usually made of thin HDF board material, which can easily splinter or crack if handled carelessly or if incorrect fastening methods are used.
Here are some important points from my experience:
- Packaging and transport: It’s best to transport the furniture in its original packaging. The back panels are the most vulnerable during transport. If the furniture is unwrapped, I recommend protecting the back panels with soft materials such as blankets, felt, or bubble wrap and avoiding direct contact with hard floors.
- Assembly: Use screwdrivers with torque control or cordless drills with low torque settings to prevent over-tightening the screws. The back panel itself should be subjected to minimal strain – sometimes it’s better to attach the back panels last and avoid tightening them too much to prevent warping.
- Wall mounting: The construction of Brimnes furniture often means thin material at the back, so I recommend reinforcing with stable brackets or mounting strips on the sides in addition to the back panel, and anchoring these securely to the wall. This minimizes stress on the back panel.
- Protective films and spacers: There are special self-adhesive protective films or foam strips that can be applied to the back. These prevent scratches from contact with the wall and reduce tension.
- Touch-up: Small damage to the back panel can be repaired with wood filler and then painted over or treated with repair pens.
I would be interested to know which tools and materials you have used so far, so I can tailor my recommendations better to your situation.
GU-LAU60
6 Jul 2022 14:03
The most important thing is to always tilt furniture carefully and preferably place it on soft surfaces. When screwing on the back panel, do not tighten the screws too much. For wall mounting, it is better to use sturdy brackets and avoid putting direct weight on the back panel.
Dopoki
7 Jul 2022 08:29
kulau schrieb:
The back panel is usually made of thin HDF board material, which can easily splinter or crack
That is correct and gets to the heart of the issue. The thin HDF material used for the Brimnes back panels has low load-bearing capacity and is vulnerable to pressure and tension forces if installed incorrectly. Therefore, I recommend the following precise measures to specifically prevent damage:
- Preparation: During assembly, ideally place the back panel on a flat, clean, and soft surface to avoid pressure marks.
- Screw control: Use a torque screwdriver or tighten screws by hand to prevent over-driving or sinking the screws. The small screws used in Brimnes back panels are particularly sensitive.
- Wall mounting: The back panel should never bear the main load when mounting to the wall. It is advisable to use sturdy brackets at the sides and top of the furniture piece, which are screwed directly into solid walls. Additionally, spacers can be installed to prevent the back panel from being pinched directly.
- Transport protection: When transporting the furniture, it is best to use the original packaging or sufficient padding between the furniture and walls or vehicle to prevent abrasion marks.
- Repair: If damage does occur, it is recommended to treat it with wood filler combined with a matching paint or touch-up pen.
These measures ensure the back panels remain intact over time without loss of function or stability. Perhaps you could also share whether you plan to permanently fix your furniture to a wall and how much experience you have with furniture assembly.
