ᐅ How can multiple Pax units be combined into a single structure?
Created on: 9 Nov 2024 19:38
noahbla
I am currently planning to combine multiple individual Pax units from IKEA into one continuous installation. My question is how to securely and stably connect these units so that they not only look like a single piece visually but are also mechanically fastened, preventing any unwanted gaps or movement.
I understand that there are various joining techniques, ranging from simple dowels to special connecting rails or brackets. Since I am focusing on both stability and a neat appearance, I would like to know which methods are particularly recommended.
Are there, for example, IKEA-specific connection methods for Pax units, or is it better to rely on third-party solutions? And how do you handle any dimensional tolerances between the individual units to achieve flush transitions later on?
Thanks in advance for your tips and experiences!
A really effective approach when connecting multiple Pax units into one system involves several steps:
- Preparation: Check all carcasses for dimensional accuracy, especially with older units where edges may have warped or shifted over time.
- Connection: The original Pax connector plates are functional but provide only limited stability for wider assemblies. I recommend additional measures:
- Installing height-adjustable base plates or feet to compensate for uneven floors.
- Connecting the side panels from the inside using sturdy wood screws, pre-drilling to protect the material.
- Adding internally mounted metal brackets for extra reinforcement between the units.
- Appearance: Since visible joints can be distracting, you can cover the outer sides with matching trims, such as T-shaped plastic profiles or wooden moldings.
Regarding dimensional tolerances: These can only be compensated by mechanical adjustment of the feet or by using thin flexible sealing strips; otherwise, unsightly gaps will appear.
I am curious whether you have planned doors within the continuous unit and if you want them to be flush-mounted? This creates additional requirements for the connections and alignment.
Dilen schrieb:
I’m curious whether you planned doors as part of the continuous unit and if they should be flush-fitted?Yes, I am planning to hang doors in front of the individual Pax frames. It is important to me that the doors are flush and that there are ideally no visible gaps between the elements. This will definitely be a challenge, especially with four units side by side.
I am considering whether to mount the doors individually or if it would be better to hang them on a continuous track to achieve a visually seamless front. Does anyone have experience or advice on the best way to implement this?
noahbla schrieb:
I am considering whether to fix the doors individually or if it would be better to hang the doors on a continuous rail to achieve a visually seamless front.This is a very interesting question, and I would like to provide some details:
- Attaching individual doors to each Pax carcass is the standard solution, but it leaves small gaps visible because each hinge area requires minimal clearance.
- Mounting a continuous rail in front of multiple units, like in a sliding door system, creates a smooth front but requires much more precision during installation and the use of rolling or sliding door fittings.
If you prefer a uniform front, you might also consider having the doors customized accordingly (for example, omitting the edge profile and working with an open edge) and installing so-called concealed hinges, which improve the appearance.
It is important that the carcasses are securely connected to each other; otherwise, the front can shift and the doors will no longer close flush.
Therefore, I recommend:
- Installing connector plates with screws and brackets
- Precisely aligning the carcasses
- Individually adjusting the doors in height and depth if necessary (most overlay fittings offer enough adjustment range)
If you choose a rail setup, you should also ensure a solid mounting of the rail and possibly floor rails to prevent wobbling.
I’m happy to help you with the selection of fittings and details if you like.
