ᐅ How can METOD doors be closed silently?
Created on: 7 Jun 2024 08:23
Ligiovanni
Ligiovanni
7 Jun 2024 08:23
I recently installed METOD interior doors but am very dissatisfied with the loud noise they make when closing. This is especially noticeable at night or during quiet moments and is quite unpleasant. My question is quite specific: What options are there to modify METOD doors or add accessories to make them close as quietly as possible? I am thinking of measures that either minimize impact noise or completely prevent doors from slamming shut. A method that is long-lasting and easy to implement would be ideal—I am not interested in complicated renovations or constant readjustments. Does anyone have practical experience or proven tips for this particular door series? Thanks in advance!
juMira46
7 Jun 2024 09:51
Hey Ligiovanni! I’m familiar with the METOD doors—they can really slam shut noisily sometimes. 😊 For silent closing, I have two reliable tips: First, self-adhesive door dampers or soft-close buffers, which you can find at most hardware stores. You stick them onto the door rebate or frame, and they absorb the impact very well.
Second, there are also door hinges with built-in damping, if your doors are compatible. If you want to avoid drilling holes, the buffers are probably the best and quickest solution. As a bonus, this also helps prevent wear on the door frames—so it’s a double win! 😎
LOGEMIN
7 Jun 2024 13:17
To precisely answer the question "How can METOD doors be closed quietly?" I recommend the following systematic approach:
- First, check whether the existing hinges operate without play or looseness. Even minimal play often causes rattling noises.
- Install so-called door dampers or soft-close mechanisms, especially models approved for interior doors.
- Another option is to attach felt or rubber buffers to the door frame, which reduce kinetic energy when closing.
Common mistakes include neglecting the door’s alignment or overlooking wear on the hinges. I also recommend choosing products with clear technical data on the damping performance.
In conclusion: A small investment in high-quality door dampers is worthwhile, as they both reduce noise and extend the door’s lifespan.
Greglau
7 Jun 2024 16:26
Soft-closing METOD doors is easiest achieved with adhesive door buffers or a soft-close fitting. Installation is quick and effective.
Palenar
8 Jun 2024 11:42
Regarding the question of how to close METOD doors quietly, I would like to take a closer look at the technical aspects.
METOD doors are usually made of medium-density fiberboard with plastic surfaces – as a result, they tend to be relatively light and less solid, which can increase the impact noise. Therefore, I primarily recommend:
- Checking and adjusting the hinges: Loose screws or improperly set hinges often cause vibrations.
- Installing damping strips: Small silicone or rubber strips placed where the door meets the frame reduce impact.
- Using special soft-close hinges: These allow the door to glide gently until fully closed.
Sometimes, inserting a thin foam rubber strip between the door and the frame helps as well – it doesn’t press on the seals but still absorbs most of the noise.
I would be interested to know on which exact door model the vibration occurs most strongly and if the doors already catch or rub slightly. These details significantly influence the approach.
warrenka57
9 Jun 2024 08:15
Palenar schrieb:
I’m curious about which exact door model experiences the strongest vibration and whether the doors already catch or rub slightly?
I think that’s important too, because doors that rub somewhere often suddenly rattle when closing. I once had serious problems with a METOD door, which I liked very much, but unfortunately aesthetics don’t matter if it keeps making noise all the time.
My advice: take your time, inspect every detail carefully, and start by testing simple buffers. If that’s not enough, you can still invest in more expensive soft-close hardware. And don’t worry, every door can be improved, even if you think it’s not “construction-identical” to other series.
