ᐅ How can Malm furniture be reinforced afterwards?
Created on: 26 Oct 2021 09:37
TANFO
TANFO
26 Oct 2021 09:37
I own several IKEA Malm furniture pieces that I would like to reinforce, as they have become somewhat unstable due to extended use and higher loads. Specifically, I am interested in methods that are structurally effective while affecting the original appearance as little as possible.
What options are there to make the carcasses and drawers of Malm dressers (especially the back panels and side panels) more stable without completely disassembling them? Are there specific reinforcement components that are recommended? Or do many people suggest traditional wood biscuits, additional brackets, and similar solutions?
I would also appreciate any experience with working on particleboard panels with laminated surfaces, as I want to avoid visible damage.
Thank you in advance for your tips and advice!
JORGERON
26 Oct 2021 09:44
I would recommend installing metal brackets on the inside at critical points. These greatly improve stability and remain unobtrusive when positioned correctly.
INGRID34
26 Oct 2021 10:03
I reinforced the back panel of my Malm chest of drawers with plywood sheets. This immediately makes the frame much stiffer and is relatively easy to do.
laureo
26 Oct 2021 14:26
When reinforcing Malm furniture, it largely depends on the problem areas. If the back panel is made of thin hardboard, you can replace or reinforce it with a thin plywood panel mounted with wooden dowels or screws—carefully pre-drill the holes to avoid damaging the material.
For the side panels, additional metal brackets are often the best solution to increase stability under load. It is important to use corrosion-resistant screws to prevent rust formation.
For the drawers, I recommend securing the guide rails to a solid surface and possibly adding extra dowels or connectors underneath the drawer bottoms, as these are often made of thin material.
It is important to avoid damaging the decorative foil as much as possible, so it is better to work on the inside or on non-visible surfaces.
hauklo
27 Oct 2021 08:12
Regarding the question of how to reinforce Malm furniture afterwards:
The Malm series from IKEA is primarily made of veneer boards, whose stability can be significantly improved with simple measures.
1. Back panel reinforcement: The original back panel is often just a hardboard sheet that can warp under load. It can be stabilized by attaching a 3–5 mm (1/8–3/16 inch) thick wood panel (plywood or multiplex). This must be cut precisely to fit flush inside. Screws or wood glue in combination provide a durable fixation.
2. Corner brackets: Especially at the corners, it makes sense to secure the inner corners with metal brackets. A minimum thickness of 2 mm (about 1/12 inch) is recommended, preferably galvanized or painted brackets to prevent corrosion.
3. Drawer reinforcement: Since most Malm drawers have only thin bottom panels and sidewalls, wooden strips can be installed as guides or reinforcements under the bottom to prevent sagging.
4. Fastening materials: Use screws with the smallest possible head diameter to avoid damage to the surfaces.
5. Processing note: Particleboard panels are sensitive to moisture, and pre-drilling screws should be done at a reduced speed to prevent surface splintering.
These measures are well-tested ways to extend the function and durability.
Deandre
27 Oct 2021 12:49
If you want to reinforce Malm furniture afterward, I would recommend first identifying the exact weak point.
Many people report that the back panels are often the cause of instability and can be significantly improved by adding a solid wood board.
Additionally, you can install small metal brackets on the inside at the connection points if you prefer no visible changes. Make sure to use the correct screw length to avoid penetrating through the surface finish.
Drawers can also often be upgraded with additional strips or stronger bottoms – this makes a big difference.
If you are working with particleboard, be sure to pre-drill and use wood glue, as this holds better than screws alone. If you want, I can provide a list of suitable screw types and brands that I personally use.
