ᐅ How can Malm furniture be refurbished using minimal tools?
Created on: 18 Apr 2023 09:17
Josephin50J
Josephin5018 Apr 2023 09:17Hello everyone,
I have a few IKEA Malm furniture pieces that already show some signs of wear, and I would like to professionally restore them myself using as little tools as possible. Specifically, I’m interested in how to fix minor scratches, dull surfaces, and possibly superficial water stains without completely resealing or doing extensive work like sanding with power tools.
I only have basic tools at home, such as fine sandpaper, brushes, cloths, and possibly a small multitool. What methods and materials are best suited for gently but effectively improving the furniture’s appearance?
I’m really looking forward to tips and proven approaches!
If you want to restore Malm furniture with minimal tools, I recommend taking a systematic approach.
First, gently roughen the surface using very fine sandpaper (grit 320 to 400) to remove dull spots and light scratches. Be sure to sand evenly and in the direction of the grain.
Afterwards, special furniture polish or waxes are suitable to rejuvenate the surface and provide protection. Applying them with a soft cloth works best.
Water stains can often be gently polished out using a mild solution of vinegar and olive oil, but test this first on an inconspicuous area to avoid discoloration.
If the stains are minor, you can cover them with wood repair markers matched to the color tone. Finally, I recommend not applying any varnish without using a sanding machine, as a thorough sanding is important for an even finish.
daalessio18 Apr 2023 10:08A good approach with minimal tools is to lightly roughen the surface and then treat it with a care wax.
If the wood is veneered, proceed very carefully, as too much moisture can damage the veneer.
Use wood care products specifically recommended for coated or veneered furniture to restore the surface’s natural appearance.
roryvin schrieb:– I agree with this. Just make sure to use the correct mixing ratio (about 1:1).
I love refreshing Malm furniture with simple methods!
One trick that always works: after light sanding, treat the furniture with beeswax. It creates a really nice and natural finish. 🙂
And: Don’t get stressed, patience can achieve so much! Good luck with your restoration!
Josephin50 schrieb:Wax is perfect for exactly that!
how to fix small scratches, dull surfaces, and maybe even superficial water stains without a complete re-sealing
