ᐅ How can Malm furniture be made more child-friendly?
Created on: 6 Dec 2023 08:12
naupalko
Good morning everyone,
I am currently considering how to make the popular Malm furniture from IKEA more child-friendly. Specifically, I am concerned with how to make the pieces safer by addressing their sharp edges, the slight wobbling stability under load, and the risk of children getting their fingers caught in drawers or doors. The appearance should also remain suitable for children without limiting functionality.
I would like to know which practical tips, proven tricks, or materials you can recommend to make Malm furniture safer and more ergonomic for children in everyday use—especially for toddlers between 2 and 5 years old. Perhaps you also know of specific upgrades, padding, or technical solutions that have proven effective?
I look forward to a practical and well-informed discussion!
blapau
6 Dec 2023 18:45
In addition to the safety measures, I recommend fitting the drawers and doors of Malm furniture with soft-close dampers. These not only reduce noise but also prevent them from slamming shut quickly, which can be dangerous for children’s hands.
Another option is to use non-slip pads on the feet to prevent the furniture from sliding. This can significantly improve stability, especially for Malm dressers.
meoreo
7 Dec 2023 07:26
Install drawer dampers, attach edge protectors, secure the furniture to the wall, and you’re done. Childproof and practical.
ju_ren
7 Dec 2023 09:02
You can also use soft fabric covers or foam rubber sheets to cushion the edges. Additionally, door locks and drawer latches are effective in preventing crush injuries.
U
uslis47
7 Dec 2023 12:54
naupalko schrieb:
I have heard of cases where the fuses simply blew under load.
This usually happens when you only drill into the drywall without using a cavity anchor. You should definitely check whether you are hitting the wooden stud behind or use the appropriate anchors right away. In some cases, it also makes sense to reinforce the panel.
meoreo schrieb:
Install drawer dampers, add edge protectors, secure the furniture to the wall, and you’re done.
Exactly – and all this should be done before children start playing with the furniture.
naupalko
8 Dec 2023 10:43
Thank you for the helpful information so far, especially the advice on screw selection and wall mounting.
One last question: How durable are the adhesive edge protectors under daily use? Should they be checked and replaced regularly? Or are there particularly long-lasting products you would recommend?
I want to avoid the protective layers peeling off and becoming a safety hazard.
