Befredrik3 Apr 2024 10:37Hello everyone,
Lately, I have been assembling IKEA Malm furniture quite often, especially cabinets and dressers, and I am wondering how to optimize the assembly process to save time without compromising quality or stability.
I am particularly interested in the following points:
- Are there any special tools or aids that make the assembly significantly easier?
- Which steps can be best combined or done in parallel?
- Do you have tips for handling the usually quite long screws and small parts?
- How can the instructions be used most effectively to avoid getting confused or wasting time?
I understand that you should never cut corners when assembling furniture, but especially with Malm, there are many similar components and screws that are used repeatedly. That’s why I’m interested in how the process could be made a bit more structured and faster.
Looking forward to your experiences and advice!
Goixkin schrieb:
It’s best to sort all parts and screws This is really essential, especially with Malm. I also recommend sorting the most commonly used fasteners like dowels and screws into small trays or magnetic containers. This way, you avoid wasting time searching during assembly.It is also helpful to carefully study the instructions and prepare the work steps in order. That means laying out all parts and screws before starting a construction phase to avoid interruptions.
Goixkin schrieb:
It’s best to use a cordless drill with adjustable torque This makes the work much easier and reduces errors. Over-tightening can damage screws or even the wood.What is your situation exactly? Are you working alone? Do you have a dedicated space for assembly? Sometimes a good work surface helps a lot, especially with larger parts.
I find the focus on speed in the main question a bit confusing. Of course, everyone wants to assemble the Malm dresser quickly, but not at the expense of stability or durability.
There are certainly some methods to speed up the process, but some tricks carry the risk of mistakes or damaged connections.
I believe it makes more sense to prepare thoroughly:
- Check all parts and report any defects immediately
- Gather tools (cordless screwdriver as well as small parts containers)
- Read through the instructions in advance and mark the more complicated steps
Sometimes it is suggested to tighten certain screws only by hand at first and fully tighten them once everything fits. I would advise against this, especially with Malm, as the components are often designed so that they cannot be easily adjusted later.
In my experience, the biggest time waster is often repeated checking to avoid errors. A well-planned and structured approach therefore brings more benefit than pure speed.
Befredrik schrieb:This usually requires following the assembly steps IKEA provides.
Oh, I love assembling Malm furniture – those clean lines and sleek design! :-) But yes, the assembly can take a while if you don’t know a few tricks.
One method I use: I prepare all the steps in advance – like putting screws and dowels from the small bags into bowls. Then I grab my cordless drill with adjustable torque, which also prevents screws from stripping or the wood from splitting.
Also super important: Before I start, I carefully read through the entire step-by-step manual. Sounds time-consuming, but when you know the sequence, you’ll know exactly when to use which parts. This avoids flipping back and forth and searching for parts.
A small challenge: Sometimes holding the large panels together if you’re working alone. A furniture clamp or even some tape, used temporarily as a third hand, helps. Be careful not to apply too much pressure, or the screw holes can shift.
So: Preparing, working calmly, using the right tools, and having a good plan really make a difference! And if things get tricky: just take a break, it saves nerves and time 😉
