ᐅ How can you increase the storage capacity of Malm drawers?
Created on: 29 Dec 2020 10:17
gustavchen
gustavchen
29 Dec 2020 10:17
I have a somewhat specific request: I own several Ikea Malm dressers with the standard drawers, which are fairly spacious but don’t provide enough storage space for some items. My question is how to increase the storage capacity of these Malm drawers without having to replace the entire dresser or buy new furniture.
I am thinking of practical and feasible solutions that better utilize the existing space inside the drawer or allow for clever expansions. What options are there to optimize the drawers—such as using interior organizers, adjustable-height inserts, or perhaps modifying the drawer itself?
Does anyone have experience or tips on how to configure more storage space in Malm drawers, even when they are already quite full? I look forward to your ideas and advice, especially regarding how complex these solutions might be and what costs could be involved.
Ramon4
29 Dec 2020 12:09
Hello gustavchen,
first of all, a very good and practical topic that affects many people!
You can indeed significantly improve the storage capacity of Malm drawers by using interior organizers. There are, for example, modular inserts that divide the drawer space vertically, helping to keep things more organized. Many also recommend completely emptying the drawers and working with small, removable boxes or compartments – this way you make better use of the depth and avoid empty space inside the drawer.
A tip: if you have some DIY skills, you can modify the drawers yourself. For example, by removing the bottom panel and installing adjustable intermediate shelves. This is more elaborate but the best solution if you need to store very different types of items.
Another option is called a “tandem organizer” or drawer divider, which you simply place inside. These are usually inexpensive and quick to install.
How much you want to invest ultimately depends on how much time and effort you can spend. A few dollars for organizers or homemade dividers is usually cheaper than buying entirely new furniture.
Good luck optimizing! 🙂
Pome60
29 Dec 2020 15:43
Ramon4 schrieb:
You can actually improve the storage space in the Malm drawers significantly with interior organizers.
Exactly! I equipped my Malm drawers with these foldable fabric boxes – super practical and they create so much more space!
Also, many people use flexible divider panels, which is brilliant! 🙂 If you also use stackable containers, you can make really efficient use of the space.
gustavchen schrieb:
optimizing the drawers with interior organizers, adjustable height inserts, or by modifying the drawer
That sounds great. That’s exactly what I did, and I love the order and extra storage space I have now.
Definitely give it a try, it costs little but gives a lot – top!
nonere
30 Dec 2020 09:22
To add to the previous information:
A very efficient way to increase storage space in Malm drawers is to use shelves or divider boards. These can be custom-made to divide the drawer height into multiple levels, allowing for better distribution and use of the available volume.
By default, the drawers are designed as one large compartment, so objects can be stacked, but unused space often remains. With properly fitting inserts, you can, for example, store flat items without hiding them under taller objects.
Additionally, I recommend using custom-fit organizer inserts made of plastic or wood to prevent items from shifting, thereby improving organization and visibility.
It should be noted that there is no simple plug-and-play solution, as Ikea itself does not officially offer retrofit shelves for Malm drawers. However, custom modifications by carpenters or skilled DIYers can significantly enhance functionality.
Costs and effort vary greatly depending on the choice of materials and craftsmanship. DIY projects with affordable materials from hardware stores are often sufficient and economical. For professional manufacturing, expect to pay approximately 50-100 EUR per shelf.
