ᐅ How can Malm drawers be installed more easily?
Created on: 10 Dec 2016 09:17
MOSESLEN
MOSESLEN
10 Dec 2016 09:17
I recently tried to assemble the Ikea Malm drawers myself, which turned out to be quite challenging. Installing and aligning the drawer runners and getting the drawers onto the rails took me a lot of time and effort. My question for you: What tips or tricks do you know to make assembling Malm drawers easier and less frustrating? Are there any tools, working techniques, or specific sequences that noticeably simplify the process? I look forward to your experiences and advice!
Neogi
10 Dec 2016 10:03
I find your question very interesting because Malm drawers are often underestimated when it comes to installation.
MOSESLEN schrieb:
Installing and aligning the drawer slides and getting the drawers into the runners took me a lot of time and effort.
Did you notice if the drawer slides were installed completely level and parallel? This is often the reason why drawers stick. I’m asking because I’ve found that many people don’t tighten the supplied screws firmly enough or, in the worst case, install the slides slightly crooked.
My tip: use a spirit level to align the slides perfectly. If you have a drill, just screw in the screws lightly first and then tighten them fully with a screwdriver—this helps prevent misalignment.
I’m curious whether you mounted the slides beforehand or attached them fully to the furniture piece first? It might also help to adjust the drawers separately about a few millimeters away from the runners before fixing everything in place.
Colby42
10 Dec 2016 11:46
Oh yes, I totally know what you mean! These Malm drawers can really drive you crazy – but don’t worry, there’s also good news! 🙂
I once just tightened all the screws by hand, aligned the drawer slides, and only then fully secured everything! That really saves a lot of stress later on. It also helps to work with two people: one holds the drawer while the other slowly slides it into the track. And hey, don’t forget: patience is key!
Neogi schrieb:
Use a spirit level and align the slides absolutely precisely.
I completely agree, that can make all the difference!
I always felt happy when I finally had the drawer running smoothly for the first time – such a small victory! 🙂
kaudi
10 Dec 2016 12:05
I would like to add a bit about my approach when assembling Malm drawers. Especially putting the parts together and hanging them on the slides requires some finesse.
First, I make sure that all parts are correctly positioned. It’s important to align the slides or rollers beforehand and apply a light oil or silicone spray to the metal tracks – even a small drop can work wonders to make the drawer run more smoothly.
I also lay the cabinet on its side to mount the slides underneath with less effort. After securing the slides, I adjust them little by little and constantly check with the drawer itself to ensure it slides in and out easily.
If the drawer won’t come out, gently lifting it while pushing in or sometimes releasing the mounting clips on the drawer sides helps. Then just try again.
If you have specific problems, feel free to ask – often the solution comes down to small details.
ronAlberto
11 Dec 2016 08:42
Let me go into more detail from a technical perspective. When assembling the Malm drawers, there are some critical factors I’ve learned from my own projects.
1. Precise alignment of the drawer slides: Even the smallest deviations from horizontal or vertical can lead to increased effort or drawers getting stuck. Check with a protractor before screwing in.
2. Assembly sequence: I recommend attaching the slides to the furniture frame first, then loosely screwing the slides to the drawer. Only fully tighten everything once the drawer is hooked in.
3. Avoid screws that split the material. For softwood, use a pilot drill bit (1–2 mm) – this makes installation much easier.
4. Lubricants: A little silicone spray or wax paste on the slides greatly improves smoothness.
5. Pay attention to the correct angle when engaging the drawer – usually, the front of the drawer must be slightly lifted and then pushed backward so the latch clicks into place.
kaudi schrieb:
Lay the cabinet on its side to install the slides underneath without much effort.
That’s an excellent tip, especially when working alone.
I’m curious, MOSESLEN, which part of the assembly did you find most challenging? The drawer latching or mounting the slides themselves?
MOSESLEN
11 Dec 2016 09:17
ronAlberto schrieb:
I’m curious, MOSESLEN, which assembly step was the most demanding for you? Inserting the drawers or mounting the rails themselves?
Thanks for the interesting insights!
The biggest challenge was actually inserting the drawers. I managed to align the rails fairly well with a spirit level, but when sliding the drawer in, I often struggled to apply the right direction and force without them jamming or catching. I noticed that the drawer front is often slightly misaligned with the cabinet frame, which makes the process even harder.
I think having a third hand or a holding device could be helpful here. The tips about slightly lifting the drawer and the tightening sequence sound great, and I will try them next time.
