ᐅ How can Malm avoid installation issues?
Created on: 7 Jul 2017 10:16
Juixla
I recently assembled an IKEA Malm shelving unit and encountered several issues that made the process more difficult than necessary. Therefore, I’m interested in learning how to generally avoid assembly problems with the Malm series.
Specifically, I’d like to know:
- What are the common sources of errors during assembly?
- Are there any special tools or aids that make the process easier?
- How can mistakes be prevented when adjusting the components?
I look forward to your detailed experiences and tips, as I would like to work without frustration and delays next time.
kulau
8 Jul 2017 09:23
benonon schrieb:
Did you try assembling your issue with additional tools or did you only use the included toolkit?
I want to revisit this because I’ve had the exact same experience. The Malm series not only requires precise screwing but often also the exact positioning of small wooden blocks, which is very difficult with just the standard tools. Using a rubber mallet or even fine sandpaper pieces for minor adjustments of the components can be a big help.
Also, recognizing the glued joints is important: Parts should be assembled so that the glue lines are not stressed or broken under load. Even small mistakes in these areas can later lead to wobbly furniture.
Maybe you could also mention which assembly steps gave you the most trouble? The connection of the back panel with the carcass or screwing in the legs? That helps to identify the key problem areas.
edisondan
8 Jul 2017 11:47
When it comes to avoiding installation issues with the Malm, thorough preparation is essential:
- Check all components for damage, especially for chipped edges or warped parts.
- Prepare your tools: in addition to a Phillips screwdriver, a hex key set is recommended, as not all screws can be properly accessed with just a screwdriver.
- Note that the assembly instructions specifically refer to small parts. Identify these beforehand and organize them accordingly. Confusing, for example, dowels can be very time-consuming.
I also recommend performing a functionality check after each construction stage, such as setting up the partially assembled unit, to detect errors early. This helps prevent damage caused by overtightened screws or misaligned assemblies.
While IKEA rarely ships low-quality parts, it is still essential to inspect everything before assembly.
risar
8 Jul 2017 13:19
Juixla schrieb:
What specific sources of errors are there during assembly?
I would like to address this question in detail because many people underestimate it:
Some of the most common sources of errors include:
- Incorrect drill holes: Sometimes the pre-drilled holes are barely visible, making them easy to overlook or confuse.
- Mixing up parts: When you have parts with similar dimensions, it’s easy to swap them, especially for elements close to the floor.
- Inaccurate sequence: Not following the instructions step by step often leads to mistakes that are difficult to fix later.
- Over-tightening: This often causes hairline cracks that weaken the wood.
In my last Malm project, I prevented parts from being mixed up with a simple trick — I placed the small parts with their corresponding wood panels. This way, when assembling, you naturally pay attention to using the correct part.
Are there specific assembly steps where you noticed difficulties on your end? Then I’m happy to offer more targeted help. 🙂
benonon
9 Jul 2017 08:12
kulau schrieb:
Maybe you could mention which construction stages were particularly challenging for you?
I can only confirm that: especially when installing the back panel and screwing in the legs, problems often occur. The back panel is usually attached only with nails, which can look crooked if not handled properly.
Tip: Equip yourself with a small hammer to install the back panel straight. For the legs, I recommend working with gentle pressure and only fully tightening the screws at the very end. This helps to align the table legs correctly.
If you have trouble aligning the legs, you can also seal the contact points with a thin felt or rubber pad to compensate for minor unevenness.
