I recently bought a Platsa shelving unit from IKEA and am wondering about the best and easiest way to clean these specific modules. The shelf is made of coated wooden panels and also has some open areas where dust and minor dirt tend to accumulate. I’m interested not only in quick and effective everyday cleaning but also in which products or methods are recommended to clean thoroughly without damaging the surface. Does anyone have tips or experience with the most suitable cleaners or tools? Advice on how to handle the holes or connection points, where dirt often collects, would also be very helpful. Thanks in advance!
Nathanaelk4 Apr 2024 07:52I would like to go into more technical detail here, as many people underestimate the cleaning process, especially with Platsa shelving units:
The surface is usually made of melamine-coated particleboard. These are fairly durable but tend to swell or lose their protective coating if exposed to too much moisture or harsh cleaners.
The small holes—connection points for the metal fasteners—often collect dirt. Therefore, I recommend the following procedure:
- Before cleaning, wipe off dust with a dry microfiber cloth.
- For the holes, a fine, soft brush (e.g., a soft toothbrush) is suitable.
- To gently remove greasy residues, you can apply a mixture of 50% water and 50% isopropanol in a fine spray mist, then wipe off with a dry cloth.
- Avoid at all costs: excessive liquid and aggressive solvents such as acetone or caustic cleaners.
Question to Moretau: How dirty is your PLATSA shelving unit? Is it affected by dust, grease, or even adhesions like stickers? This could influence the choice of cleaning method.
Nathanaelk schrieb:
Question for Moretau: How dirty is your PLATSA shelf? Is it affected by dust, grease, or adhesive residue from, for example, stickers?At the moment, it is mainly regular dust accumulating on the open areas and inside the holes. There are some minor fingerprints in a few spots, especially since the shelf is in the living room and is touched by children. There are no stickers on it yet, but this might become an issue for me soon. Is there any recommendation on how to remove sticker residue (that might end up on the surface) without damaging the material?
To remove sticker residue from a PLATSA shelving unit, I recommend the following method:
- First, gently soak the area with warm water and a small amount of dish soap.
- Then, carefully try to lift the residue using a plastic scraper or an old credit card, taking care not to scratch the surface.
- If the residue is stubborn, you can loosen the adhesive with a lint-free cloth and a bit of vegetable oil (e.g., olive oil). Let the oil sit briefly, then gently rub it off.
- Avoid using aggressive solvents or sharp tools at all costs.
- After removal, clean the shelving unit with a regular all-purpose cloth and dish soap solution, then wipe it dry thoroughly.
This way, the surface remains intact and you avoid scratches or discoloration.
Complementary to the previous recommendations, I would like to address the maintenance aspect:
Shelving units like IKEA PLATSA, which are often used in living rooms and children's rooms, benefit from regular and gentle cleaning to ensure the durability of the surface. A weekly dusting with a dry or slightly damp microfiber cloth prevents dirt from settling in.
Additionally, there are special furniture care wipes containing oils or waxes that protect the surface from drying out – in this case, please use neutral, alcohol-free products suitable for plastic-coated surfaces.
Finally, it is advisable to clean sudden stains promptly to prevent permanent residues from forming.
