ᐅ How can IKEA PLATSA furniture be used to achieve an optimal room layout?
Created on: 24 Mar 2024 20:37
gobla
gobla
24 Mar 2024 20:37
I am currently exploring how to best use the IKEA Platsa furniture series for an optimal room layout in apartments with rather limited storage space. I am especially interested in how to make the most of the modular possibilities of PLATSA, so that not only the maximum amount of storage is created, but also flexibility is maintained to use the space multifunctionally. Additionally, I am wondering if you have any tips on which combinations of cabinets, shelves, and perhaps open elements work particularly well for smaller rooms without overwhelming them.
I would also like to know how you take advantage of potential niches or unusual room layouts using the given measurements, and what your experiences are with integrating PLATSA into existing furniture.
I look forward to your opinions and practical advice!
peovin
24 Mar 2024 21:09
PLATSA is very flexible: Use the sections that are deep enough for cabinet areas you need frequently. Open shelves add light and a sense of space, while heavier cabinets are better placed against the wall. Plan ahead with the online planner to save a lot of time.
nojaus
25 Mar 2024 09:43
I completely understand that you’re putting a lot of thought into this. Small spaces especially require a lot of creativity and often some willingness to experiment. With PLATSA, I tried combining open compartments at the bottom for easy access with closed cabinets at the top for neat storage. This way, I don’t feel overwhelmed because the open compartments add airiness and structure. It’s perfectly fine if it takes some time at first to find the ideal arrangement. For me, it’s always important that I can rearrange the furniture in a new way if I move. Do you have specific room dimensions or areas that are giving you particular headaches?
Kinbu
26 Mar 2024 17:22
Hello gobla,
your question about the optimal use of IKEA PLATSA in room layout is very practical. PLATSA stands out mainly due to its modular design, which can be adapted to very different ceiling heights and room shapes.
- For niches or rooms with sloped ceilings, I recommend combining modules of different heights to make the most of the available space. The shallower models are ideal for areas under window sills.
- Open elements like shelves create a sense of lightness and work well for books or decorations, while closed cabinets provide storage for items that don’t need to be neatly arranged.
The option to choose doors and drawers individually also helps vary storage types—for clothing, electronics, or household items. A tip: combine narrow and wide modules to avoid gaps in the configuration and fill the space optimally.
If you already have furniture you want to integrate, you can place PLATSA next to it or even stack different heights on top of each other. It is important to consider the entire wall as a unit and plan with the dimensions and available light in mind. If you like, you can describe your room dimensions in more detail, and I can help more specifically.
