ᐅ How can IKEA PLATSA furniture be made child-safe?
Created on: 7 May 2021 18:12
monapa
monapa
7 May 2021 18:12
I am looking for sustainable and practical solutions to make IKEA Platsa furniture childproof. I am especially interested in measures to ensure the modules are stable and sturdy, as well as ways to minimize hazards such as easily accessible drawers or open compartments. Which child-safe locks, edge protectors, or fastening options are particularly suitable for PLATSA without compromising the design?
Furthermore, I am curious if anyone has experience with wall mounting the individual units, especially in variable combinations. Are there any tips or recommended products to secure the furniture against tipping, even with active children?
I look forward to your advice, experiences, and ideas on making PLATSA furniture safer for children, including suggestions for affordable and easy-to-implement options.
floga
7 May 2021 20:37
I can easily understand how much this topic concerns you, especially with small children at home, as safety quickly becomes the main issue. I have two children myself and also own PLATSA cabinets, so I would like to share some insights from my experience.
First of all, wall mounting was very important to us because the units are relatively tall and not very heavy, which makes them easy to tip over. We used special anti-tip devices that attach to both the wall and the furniture. It’s important that the screws are tightened securely, so it’s worth investing in good wall plugs to ensure everything stays firmly in place even during rough play.
For the drawers, we installed plastic child locks that require two hands to open. This prevents little ones from pulling everything out or getting their fingers caught.
We also added edge protectors, especially on sharp corners. Since PLATSA is customizable, we made sure no sharp edges are within easy reach. Thanks to the modular system, you can often adjust the layout with small connector pieces.
I hope this helps you feel a bit safer and inspires you. It’s not always possible to make everything perfect, but taking a few steps can make you feel much more comfortable right away.
U
usbla
8 May 2021 09:18
To make IKEA PLATSA furniture childproof, a systematic approach should be taken to analyze potential hazards:
- Wall mounting: The units come with appropriate metal brackets, which should definitely be used. It is recommended to use heavy-duty anchors for solid walls or suitable cavity anchors for drywall.
- Stability: Modular PLATSA units should not be built too tall or assembled with only a few modules per section to maximize tipping resistance.
- Child locks: Simple mechanical child locks are suitable for drawers to prevent toddlers from opening them. These locks are usually reversible without causing damage.
- Edge protection: Edge protectors that can be mounted on the furniture using a clip-on system are advisable to prevent bumps or injuries.
It is important that no electrical appliances or hazardous items are left within reach in any compartments. Regular checks of the fixings and locking mechanisms should also be part of maintenance, especially as children grow and their abilities change.
This way, common hazards associated with PLATSA furniture can be minimized without fundamentally altering the furniture.
kibutar
9 May 2021 14:46
monapa schrieb:
Which child-safe locks, edge protectors, or fastening options are particularly suitable for PLATSA without affecting the design?
For a child-safe setup of IKEA PLATSA furniture, the following technical recommendations should be considered:
- Wall mounting: The supplied wall mounting hardware is equivalent to standardized metal brackets and works reliably if installed correctly, using appropriate anchors depending on the wall type. For drywall, always use hollow wall anchors and position the fastenings symmetrically to avoid any leverage effect.
- Modular connection: To join multiple PLATSA units, the original IKEA connecting brackets are recommended, as they mechanically reinforce the assembly and further reduce the risk of tipping.
- Child safety locks: Since PLATSA drawers and doors have simple handle strips, I recommend special child safety clips that can be discreetly attached directly to the handles or inside the drawer. These require at least two fingers or a certain finger strength to open.
- Edge protection: The upper edges of open shelving units pose a particular risk of injury. Edge protectors made of soft silicone or plastic profiles, which are either transparent or neutral in color, can be applied discreetly. They can be secured with cable ties or adhesive pads.
It is important to regularly check all safety elements and ensure there are no sharp screw edges or loose parts that could pose a hazard.
Finally, a question: To tailor these tips better, it would be helpful to know whether the PLATSA units are used primarily as compact combinations or open shelving, and the children’s ages, as the requirements differ greatly depending on these factors.
