ᐅ How can IKEA PLATSA furniture be customized to fit sloped ceilings?
Created on: 17 Dec 2024 09:17
O
Onferon
Good morning everyone, I am planning to furnish my attic space with IKEA Platsa furniture, but I’m facing the challenge that the walls are not straight due to the sloping roof. My specific question is: How can IKEA Platsa furniture be custom-fitted to sloped ceilings so that they fit perfectly, without gaps, and remain stable? I have already considered cutting the pieces myself and using additional components, but I am unsure how to take precise measurements and what options are available to adapt the units to the slope without compromising overall stability. Are there any special tricks or accessories, either from IKEA or external sources, that allow flexible adjustment of Platsa furniture to sloping roofs? I look forward to your detailed tips and experiences!
blapau
18 Dec 2024 11:14
The challenge with angled finishes is often the fastening. I recommend installing angled cover plates using wood glue and small, concealed wood connectors—so-called connecting fittings or spring clips work well. These hold the plate securely without visible screws disrupting the appearance.
Additionally, you can attach brackets or small battens to the back of the cover plate, which can then be screwed to the cabinet modules. This creates a sturdy but reversible connection. It is important to do a dry fit before the final installation to check the accuracy of the fit.
For uneven dimensions, flexible sealant or narrow trim strips are suitable for masking small gaps.
koduga
19 Dec 2024 09:50
I understand that a project involving sloped ceilings can be quite challenging, especially if you don’t have much experience with such custom adjustments. I think it’s important to take your time and work step by step. What helped me back then was to first create small test fits instead of cutting all the panels right away.
It’s common to find that even minor inaccuracies can cause major headaches. In addition to the tip about using angles and battens, I would also recommend carefully sanding the edges with fine sandpaper to prevent injuries and fraying.
If you have doubts along the way, try to find someone to double-check or measure again, as that provides extra reassurance. You can do this!
