ᐅ How can Ikea Platsa furniture be creatively adapted or customized?
Created on: 22 May 2020 08:37
Anbe6
Hello everyone, I would like to start a detailed and constructive discussion on the topic “How can Ikea Platsa furniture be creatively transformed?” My starting point: I have several Platsa units in standard colors, but I don’t want to use them just as regular shelves. Instead, I want to make them significantly more unique and personal through redesign. I’m less interested in simple color changes and more in creative approaches that are also feasible with basic DIY skills, without expensive specialized tools. I’m particularly interested in ideas for surface treatments, combining with other materials, adding new functions, and unusual arrangements and installation methods. Who has suggestions or experience with creatively modifying Platsa systems that go beyond just painting or applying stickers?
pilous
22 May 2020 16:55
usron schrieb:
You can even deliberately sand the furniture unevenly to enhance its charm.
This is a popular trend, but it should be approached with caution. The original Platsa coating is made of melamine resin, which cannot be sanded down indefinitely without causing streaks.
Furthermore, I doubt that the durability won’t be affected. Creative surface treatments are fine, but they should not significantly remove structural or protective layers.
JORDON
22 May 2020 18:02
I think it’s great how all these ideas come together here! 😄 To make the versatile Platsa wardrobe even more personal, I also thought about lighting. LED strips, for example with warm white light, installed on the inside, create a really cozy atmosphere when you open the doors. This is not only eye-catching but also practical in dark rooms. By the way, you can also add small magnetic chalkboard surfaces inside to keep notes or to-do lists handy. It’s a fun and functional touch without major modifications.
LAURE-TA
23 May 2020 08:11
In addition to the previous tips, I offer a methodical perspective on remodeling Platsa furniture: - Replace hinges: Many units come with standard hinges that can easily be swapped for soft-close variants. This improves comfort and perceived quality. - Interior fittings: Use removable baskets made of metal or wood, which you can customize yourself to add contrast and texture. - Cover fronts: Instead of just painting, I recommend using self-adhesive vinyl with textured surfaces, as it is less sensitive than paint. - Combine with other materials: Attaching aluminum or copper strips to the edges creates an industrial look, which is currently very trendy. - Care instructions: When changing surfaces, be sure to carefully follow the processing guidelines of the materials (e.g., temperature, humidity).
barsar
23 May 2020 11:49
Brief and efficient: For creative remodeling, it’s worthwhile to replace handles, wallpaper the back panels, and rearrange the furniture modularly. Additionally, integrating LED lights helps create a unique look quickly.
Anbe6
23 May 2020 13:02
KUDAISY schrieb:
Besides painting, you can also apply vinyl films, decorative paper, or even liquid epoxy resins. When using epoxy resin, pay attention to the compatibility with the surface and the required curing times.
Thanks for the tip, the epoxy resin sounds interesting, but I have concerns about how it handles on the panels. Does anyone know if the typical IKEA panels are really suitable for this? Or has anyone tried it already? Also, are there alternatives to applying resin that are similarly durable and visually high-quality?
