ᐅ How can Ikea PLATSA doors be fitted with custom handles?
Created on: 10 May 2020 18:27
Guma37
Guma37
10 May 2020 18:27
I am currently planning to customize my Ikea Platsa cabinet doors with individual handles. I have some questions about the best way to proceed when deviating from the standard handles. Specifically, I am interested in the available mounting options, how to pre-drill or possibly use existing holes, and which materials are suitable for attaching sturdy, visually appealing handles that will last over time.
Are there any experiences with self-installed or purchased handles that are not from Ikea? Are there any considerations regarding the doors themselves, such as load-bearing capacity or material thickness?
I look forward to practical tips and personal experiences, ideally also including recommendations for necessary tools or custom fittings. Thanks in advance!
bijo54
10 May 2020 19:03
simple option: Unscrew the old handles and use new handles with the same hole spacing. If the spacing is different, you will need to drill new holes – mark the spots first and pre-drill with a small drill bit to prevent the MDF from chipping.
Attach the handles with screws from the inside of the door. The doors are thin, so do not use screws that are too long.
glamo
11 May 2020 08:46
Hello Guma37,
your question is very relevant for anyone wanting to customize PLATSA. The doors are made of coated chipboard with a relatively thin door thickness of about 16 mm (0.6 inches). You need to be very careful when installing new handles.
Here is a detailed guide:
- Preparation: First, remove the existing handles and check the position of the holes. By default, Ikea uses metric screws with a diameter of approximately 4 mm (0.16 inches).
- Planning: If you want different handles, the mounting holes must either have the same measurements or you will need to drill new holes. For new holes, I recommend precise measuring with a ruler and marking the drill points on both sides of the door to ensure accurate drilling.
- Drilling: Since the material is quite thin and delicate, use a drill bit with a small diameter and pre-drill first (e.g., 2-3 mm (0.08-0.12 inches)) to avoid damaging the material. Ideally, use a drill press or drill carefully from both sides to prevent splintering.
- Handle selection: Heavier handles require correspondingly strong fasteners. Make sure the screws are not too long, as they might go through the back of the door. Screws around 12-15 mm (0.5-0.6 inches) in length are recommended.
- Alternative fastening methods: Some use special adhesives (e.g., strong double-sided mounting tape or glue), but I advise screwing for stability and load capacity.
Additionally, I recommend using a drill with a depth stop to avoid drilling too deep.
A question for you: What kind of handles do you have in mind? More modern, classic, metal, or wood? This could also influence the type of fastening required.
Jeanbar
11 May 2020 14:32
Hello Guma37,
I’d like to add some basic tips that are often overlooked, especially when working with PLATSA doors.
bijo54 schrieb:
If the distances are different, you need to drill new holes – mark them first and pre-drill with a small drill bit
This is a very important reminder, particularly for chipboard or MDF-like doors. I recommend that after removing the original handle screws, you consider filling the holes with small wooden dowels or wood filler if you plan to reposition the handles, since visible old holes can negatively affect the appearance.
Also, it’s a good idea to work on the doors lying flat on a soft surface to prevent chipping.
glamo schrieb:
For new holes, I recommend precise measurement with a ruler and marking the drill points on both sides of the door
Very important: You should mark the drill points exactly in the center to ensure the screws hold firmly and the handles do not have any play. It’s best to use a center punch or a small awl to guide the drill bit.
If you’re interested: there are special screws for furniture fittings that have countersunk heads and are designed specifically for thin panels. These can be found at hardware stores or furniture accessory suppliers and may provide better holding strength.
I hope these tips help you! If you like, I can also send you a short checklist to prepare.
PULAU
12 May 2020 10:11
To add to this, I would like to emphasize that, besides the mechanical fastening, the load on the door caused by larger or heavier handles should also be taken into account. PLATSA doors, as already mentioned, are made of thin material and can only tolerate a certain amount of stress before long-term damage such as breaking out or warping may occur.
A tip: If you want to install handles made of metal or heavier materials, make sure to use screws combined with washers to distribute the pressure more evenly. This reduces the risk of the screws loosening during use or damaging the door.
If not already done, consider using a drill with a clutch to prevent overdrilling. Also, using suitable screws with the appropriate thread length helps to ensure a secure hold—furniture screws are best suited for this.
I hope these tips provide additional guidance for a stable and visually pleasing handle installation on Ikea PLATSA doors.
