ᐅ How can Ikea PLATSA be adapted for sloped ceilings?
Created on: 29 Oct 2024 18:47
O
Onclemens
Hello everyone, I am planning to install an IKEA Platsa shelving system in the attic of my house. The issue is that the ceiling height varies due to the sloping roof, so a traditional straightforward setup is not possible. My question is: what is the best way to adapt IKEA Platsa for sloped ceilings, especially when aiming for the most efficient use of space while taking the angled walls into account? Are there proven methods, modifications, or additions to fit the cabinets precisely to the roof slope without sacrificing stability and functionality? I look forward to any tips and experiences!
PeoDaniel
30 Oct 2024 10:45
Here is how I see it: If you want to work with Platsa, you should especially pay attention to the following points:
- Be sure to plan the maximum height of the shelving system so that the top edge does not touch the sloped ceiling.
- Measure the slope carefully, particularly the height in individual sections, to avoid using units that are too large.
- If needed, use the open frames from PLATSA, as they offer more flexibility for adjustments.
- For the slopes, custom-cut covers are recommended, which can be mounted on top of the cabinets—especially if you want to avoid gaps.
- Finally, check whether additional stabilizations with wall brackets are necessary, since slopes may exert different loads.
If you want, I can also share some tips on preparing the cuttings.
Dilen
30 Oct 2024 11:29
PeoDaniel schrieb:
For angled sections, custom-cut covers that can be mounted on the cabinets are recommended—especially to avoid any gaps.
Exactly, that’s a crucial point. The cover panels really make a big visual difference.
I would add that it’s best to use more durable material here, which can also be easily adjusted in color or with a veneer to seamlessly blend with the PLATSA surface.
Also, when installing, be sure to check that the angle does not cause any tension or pressure on the modules—this helps prevent damage. Indirect fastening using brackets or spacers can work wonders.
