ᐅ How can Ikea PLATSA be adapted for sloped ceilings?
Created on: 29 Oct 2024 18:47
O
Onclemens
O
Onclemens
29 Oct 2024 18:47
Hello everyone, I am planning to install an IKEA Platsa shelving system in the attic of my house. The issue is that the ceiling height varies due to the sloping roof, so a traditional straightforward setup is not possible. My question is: what is the best way to adapt IKEA Platsa for sloped ceilings, especially when aiming for the most efficient use of space while taking the angled walls into account? Are there proven methods, modifications, or additions to fit the cabinets precisely to the roof slope without sacrificing stability and functionality? I look forward to any tips and experiences!
Dilen
29 Oct 2024 19:12
Hello Onclemens, your issue is very interesting and technically challenging, especially because the PLATSA system, with its modular components, is flexible on one hand, but on the other hand not specifically designed for sloped ceilings. I use a similar solution myself and recommend the following approach to adapt PLATSA to sloped ceilings:
- First, you should measure the slope of the ceiling precisely, including the minimum heights and angles. This is the only way to avoid standard dimensions not fitting.
- Use the low, flat PLATSA units in the lower area, where the slope is steepest. Taller units can be placed further inside against the high wall.
- A combination of PLATSA units and custom-cut wall plates or beams can help to visually adapt the cabinet fronts to the slope. For example, you can install an adjustment rail at the bottom on which the cabinets are leveled.
- For the upper edge facing the slope, it makes sense to cut cover panels at an angle and screw them in place. You have to mark the slope precisely and may need a router bit.
- Another idea: The PLATSA system allows you to build units to measure. This way, you can create lower modules and complement them with open shelves that fit under the slope.
Do you already have specific measurements or perhaps a sketch? That helps a lot to address special challenges.
juMira46
29 Oct 2024 19:34
Dilen schrieb:
A combination of PLATSA units and custom-cut wall plates or beams can help visually align the cabinet fronts with the slope.
Exactly what I was thinking! 😄 I believe a bit of hands-on work can really turn IKEA panels into something personal and unique. And honestly, who wouldn’t want their PLATSA to become a little sloped-ceiling miracle?
Oh, and one more thing: I always grouped my modules so that where space got really tight, I removed the back shelves and simply left the front open – this keeps things airy and avoids a cramped feel. Of course, you do need a bit of courage to experiment. 😀
GALEO4
30 Oct 2024 07:52
juMira46 schrieb:
I think a bit of DIY effort can turn IKEA panels into something personal and unique.
That may be, but I doubt that half-hearted makeshift solutions really get the most out of a system that can be somewhat rigid. PLATSA is designed for standard walls, period. If you really need furniture for sloped ceilings, you should either go for a custom-made piece or at least choose a different system—such as shelving units that can be more easily adjusted in depth and height.
A truly clean result is only possible if you cut wood panels precisely and maybe build the carcasses yourself. IKEA is IKEA. So you will always have to accept some compromise. This sounds like a lot of effort for a possibly mediocre outcome.
Dilen
30 Oct 2024 08:16
That is basically true, but the ingenious modularity of PLATSA also offers customization options if you take the time to work with the system.
For example, individual side panels can be cut or modified to adjust the cabinet dimensions to fit a sloped ceiling. This only requires good tools, especially a fine saw, and some experience. The connecting mechanisms, such as metal hinges and dowels, can largely be preserved.
Additionally, by stacking the individual components, you can create flexible height variations that might be more difficult to design with custom-made furniture. I think this is a major advantage, especially when comparing the effort of custom furniture making versus Ikea modularity.
KAULIS
30 Oct 2024 10:03
Regarding the question of how IKEA PLATSA can be adapted for sloped ceilings, here is an objective overview:
- PLATSA is modular, featuring fixed width and depth dimensions. Direct adaptation to slopes is usually achieved by trimming the side or back panels.
- Trimming the side panels should be done precisely using appropriate power tools to avoid damaging the material structure.
- For finishing against the sloped ceiling, custom-made cover panels from thin wood or plywood are recommended, shaped to fit the angle of the slope.
- Stability is ensured when the modules are placed on a solid base or securely fastened to the wall.
- Alternatively, adjustable wooden fillers can be used to close unwanted gaps; these can be painted to match the color.
Overall, the more accurate the measurements and cutting, the better the result. Planning with CAD software or at least a to-scale sketch is therefore advisable.
