ᐅ How can IKEA PAX wardrobes be optimally placed in attic rooms?
Created on: 23 Aug 2018 08:17
Stjepan7
Stjepan7
23 Aug 2018 08:17
I am planning to install an Ikea PAX wardrobe in my attic room, but I am facing the challenge of making the most of the limited space and often sloped walls. Especially with sloping ceilings, it is difficult to position standard furniture so that it remains functional while not blocking usable space.
How have you placed your PAX wardrobes in rooms like this? Are there any clever tips regarding the choice of height, width, or accessories to best adapt the wardrobe units to the roof slope?
I’m also interested in experiences with custom modifications, such as trimming the back panel or adjusting the height to maximize the use of space.
Thanks in advance for your advice and shared experiences!
keosau9
23 Aug 2018 09:42
I would place the PAX wardrobe directly against the tallest wall, preferably without a sloped ceiling above the wardrobe. If that is not possible, corner solutions with low shelving units under the slope can help, placing the larger PAX sections mostly along the straight walls.
taotis53
23 Aug 2018 11:29
When placing PAX wardrobes in attic rooms, it is advisable to first accurately measure the available standing height under the slope. In particular, the distance from the floor to the sloped ceiling at various points is important to select suitable wardrobe heights.
IKEA offers flexible modules that can be adjusted in height. If necessary, lower units can be combined with matching doors or drawers to efficiently utilize the entire wall space.
Another proven approach is to use wardrobe units without a back panel in sloped areas to fit the slope directly to the interior space. In some cases, it may also be worthwhile to modify or shorten the back panel itself to better accommodate the slope.
The wardrobe depth of PAX (commonly 35 or 58 cm (14 or 23 inches)) should also be taken into account to maintain enough room for movement in the room.
parbau
24 Aug 2018 07:03
taotis53 schrieb:
In particular, the distance from the floor to the slope at different points is important to choose suitable cabinet heights.
Exactly! Roof slopes can be as unpredictable as the weather – and precise measurements are the only way to get it right. 😉
I once experimented a bit with the PAX modules, and the combination of lower cabinet sections under the slope and tall single units along the straight wall was a great solution.
It’s also helpful, besides the classic arrangement, to use flexible interior fittings to optimize storage space despite the angled roof surface. That way, the corner doesn’t feel like wasted space but rather a well-utilized area.
And don’t forget: you can always try out configurations on-site at the store or use the planning tool to see how the modules complement each other well. 😉
NUPIN
25 Aug 2018 16:48
Hello Stjepan7!
Your question hits the mark—I had exactly the same problem and only recently found a solution! 😊
My advice is: don’t be afraid to customize the cuttings! That means simply shortening or even omitting the back panels on the PAX units for the sloped side to make the best use of the slope. Doors can also be adjusted—this way you get almost tailor-made wardrobes without having to buy completely new furniture.
I also recommend placing the PAX wardrobes directly against the straight walls and filling the sloped area with shelves or storage boxes. The combination makes all the difference.
Most importantly: have fun planning! I think especially in attic spaces, with a bit of creativity, you can create great custom solutions. Good luck!
