ᐅ How can you retrofit soft-close mechanisms on IKEA PAX doors yourself?
Created on: 6 May 2024 17:03
dawidnar
dawidnar
6 May 2024 17:03
I own an Ikea PAX wardrobe system with multiple doors that currently have no soft-closing mechanism. I’ve noticed that the doors sometimes close quite loudly, which bothers me in the long run. Therefore, I am looking for a way to retrofit these PAX doors with integrated dampers without having to replace the entire doors or the wardrobe system.
I’m mainly interested in practical options, either through retrofit dampers, special door hinges with a soft-close function, or other technical solutions that Ikea does not offer as standard.
It is important to me that the solution can be implemented relatively easily by a DIY approach and is not too expensive. Does anyone have experience with specific products, instructions, or tips on how to effectively add damping to Ikea PAX doors? I would appreciate any recommendations, including advice on tools, mounting, or potential challenges during installation.
Thank you in advance!
Dilen
6 May 2024 18:17
dawidnar schrieb:
I noticed that some of the doors slam quite loudly, which bothers me in the long run.
The issue with slamming doors is fairly common with PAX systems. If you want to retrofit the doors with dampers, the technical options mainly fall into two categories: either you replace the hinges with soft-close hinges that have built-in damping, or you install separate dampers (such as door buffers or damping pads).
1. Soft-Close Hinges
If you decide to replace the hinges, make sure they are compatible with PAX doors. Although Ikea does not offer official retrofit hinges, many third-party suppliers sell soft-close hinges with mounting kits that fit. It is important that the mounting holes line up or that you are prepared to drill small additional holes. This method is the cleanest since it directly addresses the hinge mechanism and ensures smooth door movement.
2. Retrofit Dampers
These small dampers, which are attached to the frame or the door, can reduce the closing speed. They are often rubber buffers with springs or hydraulic dampers that are installed individually. Installation requires precise positioning; otherwise, the door may rub or the damping may not function properly.
I would ask you:
- What type of doors do you have (mirror doors, wood fronts, glass)?
- How much space is there between the door and frame, and how are the hinges currently mounted?
With this information, the best solution can be recommended more accurately.
Important: When retrofitting, always ensure precise alignment and that the damping force is sufficient but not too strong to avoid deforming the door.
Nabla64
7 May 2024 09:42
dawidnar schrieb:
Does anyone have experience with specific products, guides, or tricks for effectively retrofitting Ikea PAX doors with soft-closing mechanisms?
Hello Dawid,
I would be happy to provide you with a clear guide on how to retrofit your PAX doors with soft closing, without too much effort:
- Step 1: Choosing the solution
For PAX doors, I recommend soft-close hinges with integrated dampers. If you don’t want to replace the entire hinge, self-adhesive dampers are an affordable alternative.
- Step 2: Removing the doors
Carefully lift the doors off the existing hinges. It’s best to note the screw positions in case you need to adapt any drill holes.
- Step 3a: Installing soft-close hinges
Purchase hinges that fit, ideally with dimensions matching the original or Ikea standard (usually 35mm cup drilling). Pay attention to the screw spacing. Screw the new hinges in and remount the doors on the cabinet.
- Step 3b: Alternative: self-adhesive dampers
If you don’t want to replace the hinges, attach small door buffers (e.g., silicone or spring-based) at the appropriate spots on the frame or door. The door must close against the damper to achieve the soft-closing effect.
- Step 4: Fine adjustment
Test how the doors close and adjust the damper or hinge positions until the closing movement is smooth and quiet.
Common mistakes include:
- Incorrect drilling causing tension or uneven closing.
- Choosing dampers that are too hard or too soft, which limits functionality.
If you prefer a minimally invasive approach, I recommend soft damper strips that stick to the inside of the door and meet the cabinet frame when closing.
One more tip: Ikea has previously offered soft-close hinges for some PAX doors – you might find discontinued accessories on classifieds or furniture marketplaces.
If you like, I can provide you with a list of damper models to consider.
Dilen
7 May 2024 12:10
Nabla64 schrieb:
If you prefer a minimally invasive approach, I recommend the soft damping strips that are glued to the inside of the door and meet the cabinet frame.
That’s exactly what I wanted to add.
These damping strips made of silicone or soft plastic are a quick, inexpensive solution if you don’t necessarily want to replace the hinges. However, you should first check whether the gap between the door and frame is wide enough so that the strip does not rub when closing.
One small note: some of these strips may lose their adhesive strength or yellow over time, so upgrading to metal dampers might be worthwhile if you want long-term comfort.
If you like, I can also advise you on positioning the dampers to ensure smooth door movement and prevent jamming.
