ᐅ How can Ikea Pax doors be fitted with handles in different colors?
Created on: 21 Jan 2018 09:17
Russeldi49
Hello everyone, I am planning to install IKEA Pax doors in my home, but I want to equip them with handles in different colors to give my interior a unique look. My question is: How can these doors be fitted with handles in various colors without compromising functionality and appearance? Are there specific installation methods or recommendations to consider? Perhaps someone has practical experience or tips on the best way to achieve this—especially regarding the attachment of the handles, suitable screws, or possibly alternative types of handles.
Russeldi49
22 Jan 2018 07:58
valerie-tr schrieb:
If you like, I can write a guide on how I installed handles myself, including tips on marking the handle positions.
I would really appreciate that, thank you! I definitely want to avoid handles being misaligned afterwards or screws damaging the wood. I also find the idea of using threadlocker interesting—I’ve only known it from cycling so far. I plan to make the doors as durable and visually appealing as possible. Maybe a quick question beforehand: What tools do you need for installing and adjusting the handles?
V
valerie-tr
22 Jan 2018 09:16
Gladly:
For installing the different-colored handles on IKEA Pax Nexustüren, I recommend the following procedure:
- Tools:
- Cordless drill with adjustable torque (to prevent overtightening)
- Spirit level or installation template (for precise alignment)
- Pencil (for marking drill holes)
- Phillips screwdriver
- Small drill bit (3–4 mm (0.1–0.15 inches)) if you need to drill new holes
- Thread-locking compound (optional)
- Procedure:
1. If there are existing holes in the doors, check the hole spacing and note it for all handles.
2. For new holes, use a template or spirit level for accurate marking.
3. Drill carefully only on the inside of the door to avoid damaging the front surface.
4. Insert screws lightly at first, check the alignment with the spirit level, then tighten fully.
5. For handles in different colors, try to choose handles with the same hole spacing for easy replacement.
6. For different handle styles, make sure the handle remains easy to grip from an ergonomic point of view.
If you want, I can also provide tips on where to find especially colorful handles that fit.
fasau
23 Jan 2018 14:29
Great topic! I also chose different handles for my Pax units in my apartment, even in bright red and blue. It’s really fun to add a bit of color like that! 😃
My tip: It’s best to measure the handle size first and then order two or three different samples. That way, you can check exactly how the color and shape look at home before installing everything. At first, I was worried it might look too busy, but with clear planning, it turned out very stylish!
Also: Take your time when tightening the screws! Nobody likes over-tightening, and it’s better to measure carefully once than to drill holes twice. Good luck!
FLONE41
24 Jan 2018 18:46
I think it’s great that you’re asking here, as I had similar thoughts at the beginning of last year, and it was confusing because IKEA itself offers quite limited handle options – especially when it comes to colors.
I fully understand how important it is for the handles to remain functional and for the doors to close properly. In my experience, different colors look great, but you really have to make sure the sizes are consistent; otherwise, it quickly looks chaotic.
If you’re still unsure, maybe try one handle per color on a single door before redesigning the entire front significantly. I was initially concerned about how mixed handles would look after installation, but I often received positive feedback. I wish you lots of patience, as sometimes it takes a while until everything fits perfectly!
