ᐅ How can Ikea Pax wardrobes be used for storage in the garage?
Created on: 23 Apr 2024 19:37
teoke
teoke
23 Apr 2024 19:37
I am planning to create additional storage space in my garage and have been considering using the IKEA PAX system for this purpose. My specific question is: How can IKEA PAX wardrobes be effectively used in a garage as storage, so that they are protected from moisture and can optimally accommodate mostly bulky or seasonal items? I am particularly interested in how to best protect the wardrobes against typical garage conditions such as temperature fluctuations, dust, or humidity, and whether there are any recommended modifications or accessories to ensure organization and stability.
What are your thoughts on using PAX systems in garages, and what tips or experiences can you share regarding installation, protective measures, and useful equipment? Thank you in advance!
MOMIRA
23 Apr 2024 20:41
teoke schrieb:
How can IKEA PAX wardrobes be effectively used in the garage as storage, ensuring they are protected from moisture while also optimally accommodating mostly bulky or seasonal items?
I would recommend reinforcing the back panels of the PAX wardrobes with a water-resistant membrane and installing the wardrobe on an elevated platform or plastic feet to avoid direct contact with any moisture on the floor. Additionally, good ventilation in the garage helps to reduce humidity.
GiRoyce
24 Apr 2024 07:06
teoke schrieb:
How can IKEA PAX wardrobes be used effectively for storage in a garage so that they are protected from moisture and bulky or seasonal items can be stored optimally?
A garage is often not an ideal location for PAX units, as they were originally designed for indoor use. Therefore, I recommend the following approach:
- Ensure the garage is well sealed and as dry as possible.
- Use moisture barriers such as special protective coatings or water-resistant insulation panels behind the wardrobes.
- Raise the feet of the PAX wardrobes, for example with sturdy plastic spacers or wooden strips, to avoid direct contact with the floor.
- Choose doors that close tightly and use plastic drawers or boxes for smaller, more sensitive items.
- Consider temperature fluctuations: PAX materials can swell if exposed to moisture, so regular checks are advisable.
If you want to store heavy tools or car care products, pay attention to the load-bearing capacity of the shelves. Plastic boxes can expand storage options and provide extra protection for the contents. A lockable wardrobe would also be beneficial for secure storage.
This way, you can use the system in a garage without risking significant damage.
theo63
25 Apr 2024 14:52
GiRoyce schrieb:
A garage is often not an ideal location for PAX, as the modules were originally designed for indoor use.
I agree completely and would like to add that when using PAX in garages, the value of the furniture should not be overestimated. The particle boards are not designed for permanent moisture or temperature fluctuations, which can lead to warping and damage.
MOMIRA schrieb:
I would recommend reinforcing the PAX wardrobe backs with a water-repellent foil and installing the wardrobe on an elevated base or plastic feet.
These measures are certainly correct, but without adequate climate control in the garage, the risk remains. Alternatively, more durable metal garage shelving or specially coated cabinets should be considered when it comes to long-term storage of bulky items.
Shouldn’t we also consider whether it really makes sense to use furniture with rather sensitive surfaces in a rough environment? A cost-benefit analysis might be helpful before making a purchase.
