ᐅ How can the Ikea Pax system be optimized for multifunctional use?
Created on: 6 Oct 2022 20:03
PIN_PLO
I am considering how to best optimize the Ikea Pax wardrobe system for multifunctional use. Specifically, I am interested in the possibilities of combining the modular components such as shelves, interior fittings, or sliding doors in a way that the wardrobe not only provides storage for clothing but can also serve as a workspace, media station, or even a room divider.
I am particularly curious about how to cleverly work with the existing modular elements without major additional investments or carpentry modifications. Do you have any experience or ideas on making the Pax flexible and multifunctional to better suit different living situations?
bapar schrieb:
One question for the thread starter: What specific multifunctional uses do you have in mind for the workspace or room divider?Good question. I am thinking of a cabinet that serves as a traditional wardrobe during the day but also includes a fold-out desk or laptop workspace in a smart configuration. As a room divider, it should create a visual separation between the sleeping and living areas in a small apartment without feeling too bulky. It would be great to incorporate sliding doors and open compartments, possibly combined with adjustable lighting.
A very interesting starting point. I believe that to optimize the Pax system for multifunctional use, one should not focus solely on the storage system itself but also plan for accessories that are not usually included as standard. For example, integrated power strips or USB ports placed in strategic locations can make both media use and a workspace setup much easier. For lighting, I recommend flexible LED strips with dimmer functionality. Another consideration: the back panels can be removed or replaced – using different surfaces (mirror, glass, wood) could influence how the space is used. In small apartments, it is also advisable to combine open compartments with laundry baskets that can be easily removed – this creates additional flexibility. Furthermore, it is important not to exceed the maximum load capacity, especially when movable or foldable elements are incorporated.
I would like to point out that the multifunctional use of the Pax system is not only a technical challenge but can also be emotionally significant. A cabinet that serves as a workspace or room divider changes the everyday interaction with the furniture and may cause uncertainty for some people because the storage space in a central location is being repurposed. I believe it makes sense to also consider the psychological aspect, for example, whether the cabinet can be easily reconfigured or if the system is too complicated, leading users to stick with the “classic” use instead. Perhaps a modular design with simple plug-in or click-in elements that can be rearranged at any time would help here.
noken schrieb:
A cabinet that serves as a workspace or room divider changes the everyday interaction with the furniture and can cause uncertainty for some peopleThat’s an important point I hadn’t considered before. Perhaps the shift from purely storage to multifunctional use makes the most sense when the modifications are easy and low-effort. That’s why I like the idea of using clamp or plug-in systems that can be easily adjusted. I’m also thinking about adding modular elements like small rolling containers or trays that can be removed or repositioned as needed. If the Pax remains primarily flexible, it will likely provide a more comfortable user experience.
PIN_PLO schrieb:
If the Pax remains primarily flexible, it certainly creates a more pleasant user experience.I agree with that. I would like to add: For a stable yet flexible use, I also recommend enhancing the classic Pax structure with accessories, such as adjustable shelves that are easy to install and remove but remain securely in place. Open compartments for display and closed compartments for hidden storage can be well combined and support the multifunctional concept.
