ᐅ How can Ikea PAX wardrobes be optimally integrated into small alcoves?
Created on: 12 Dec 2022 08:12
neogo
Hello everyone, I am currently planning to install an Ikea PAX wardrobe in a relatively small niche in my apartment. The niche is approximately 120 cm (47 inches) wide and 60 cm (24 inches) deep, slightly narrower than the standard PAX modules. My main question to the community is: How can Ikea PAX be best utilized in small niches, both functionally and visually?
I would appreciate tips on selecting the right modules, possible modifications, combined with good ideas for interior organization and appearance. Also, experiences on how to use PAX as efficiently as possible despite spatial limitations, and whether certain fronts or interior fittings are particularly suitable.
Thank you in advance for any helpful contributions!
SauDietmar
13 Dec 2022 08:12
neogo schrieb:
Does anyone have experience with combining PAX units with built-in niche lighting, especially regarding power supply?
I would like to add to edisondan’s comment that when using battery-powered LED strips, it is important to ensure that the charging cycles are convenient and that the lights can be easily removed. This can otherwise become inconvenient in tight niches. Some users enhance this setup by using magnetic mounts.
Repar
13 Dec 2022 10:30
If the niche is really very narrow, I recommend adjusting the depth of the Pax wardrobe units. The standard depth of 58 cm (23 inches) often does not fit, leaving no gap. You can easily shorten the back panels and shelves if you work precisely.
neogo
14 Dec 2022 09:18
To conclude my research, I want to thank you all for the valuable tips!
In summary, I note the following:
- precise measurements and possible adjustments are essential,
- sliding doors offer space-saving advantages,
- flexible interior fittings with adjustable elements increase usability,
- LED lighting (preferably battery-powered) enhances comfort,
- light-colored fronts or mirrored backsplashes visually enlarge the space.
I will now start planning and hope to find a solution that showcases PAX perfectly in my small niche. If I have further questions later, I’ll gladly return to this.
