ᐅ How can Ikea PAX wardrobes be expanded with additional shelves?
Created on: 7 Jun 2023 08:37
Iraklisf61
Iraklisf61
7 Jun 2023 08:37
Hello everyone, I am currently looking into how to expand an IKEA PAX wardrobe system with additional shelves in order to optimize storage space. Specifically, I am interested in official or unofficial options for adding more shelves or inserts into existing PAX frames without compromising stability or functionality. I would also like to know if there are compatible alternatives from other IKEA series or if it makes sense to supplement with accessories from the open market. Perhaps someone has tips regarding dimensions, materials, or proper installation to ensure a clean and durable extension. I look forward to your experiences and clear, easy-to-follow instructions!
koduga
7 Jun 2023 09:14
I can completely understand that you want to optimize the extension of your PAX wardrobe, especially since space gets tight quickly when using only the standard shelves. In my experience, it’s important not to rely solely on the official IKEA shelves but sometimes to choose flexible solutions, such as adding extra supports or brackets that you can install yourself. I was initially unsure if this might compromise stability, but firmly screwed-in shelves work quite well. However, as you mentioned, it’s still important to respect the load capacity of each shelf and avoid distributing too much weight over small areas. Have you considered making your extensions modular so you can stay flexible for future changes?
CHENFAR
7 Jun 2023 11:22
For efficient expansion of IKEA PAX closet systems, I recommend the following structured approach: - Check the exact dimensions of your PAX frame (width, depth, and height), as these can vary between models. - Use only original PAX shelves or compatible products that use the same mounting holes. This ensures stability. - If additional shelves are needed, you can purchase extra brackets that are precisely designed for the system to prevent slipping. - For reinforcement with heavy loads, it is advisable to use shelves with higher load capacity, such as plywood boards of the appropriate thickness, provided the mounting holes fit exactly or with adapters. - Alternatively, some users have reported positive experiences with systems specifically designed for modular closets, but it is important to pay close attention to exact measurements and hole spacing. Important: IKEA’s warranty generally voids if unofficial modifications are made. For assembly, it is always recommended to use the included mounting hardware or corresponding screws to ensure sufficient stability.
COLEBAR
7 Jun 2023 14:09
Direct tip: You can buy additional shelves simply by ordering extra PAX shelves separately. If you want more flexibility, get suitable brackets so you can add shelves later. Important: Check the load capacity before installation! Nothing more is necessary.
Nakar33
8 Jun 2023 07:53
Hello Iraklisf61, I would like to explain the topic in more detail here, as there are many aspects of PAX extensions that are often underestimated. First, you should know that PAX frames come in various widths (including 50, 75, and 100 cm (20, 30, and 39 inches)), and the available shelves differ depending on the width. While they fit mechanically, any modifications—such as cutouts for cable passages or special brackets—vary for each version.
An important point concerns the supplied fittings: the shelves are usually hung on dowels or strip rails that fit into the pre-drilled hole rows of the frame. The hole spacing is 32 mm (1.26 inches), which is a classic dimension in furniture construction and something you should keep in mind when buying additional components.
If you want to cut additional shelves yourself or use alternative materials, I strongly recommend measuring the exact hole dimensions and drill diameters beforehand and also checking the maximum load capacity. A shelf that is too heavy or poorly fixed can not only damage the wardrobe but also pose a safety risk, for example if the unit tips over.
More practical tips:
- Pay attention to the alignment of the hole rows in relation to the installation height. Incorrect assembly often makes later adjustments difficult.
- Consider possible reinforcements, especially if you plan to store heavy items. There are metal brackets or additional support rails available as accessories that can be mounted on the back panel.
- If you want more flexibility, you can use pocket fittings that are adjustable along the hole rows to fine-tune the shelf positions.
- Before buying more shelves, check the condition of the existing fittings, as they often show wear or deformation over time.
I hope this helps. If you can describe more precisely how you want to expand the storage space, I can offer more tailored advice for your project.
