ᐅ How can the Ikea Pax system be expanded modularly?
Created on: 28 Jul 2020 09:17
katejo
katejo
28 Jul 2020 09:17
Good morning everyone, I recently bought an Ikea Pax wardrobe system, but now I need to expand it modularly to perfectly adapt it to my changing storage needs. Therefore, I’m especially interested in the question: How can the Ikea Pax system be expanded modularly? What options are there to flexibly add more units, accessories, or customizations to the wardrobe without much effort, and which components or system parts are particularly useful for this? I would appreciate any tips and personal experiences!
Josan
28 Jul 2020 10:54
Hello katejo, to expand your Ikea Pax system modularly, there are some important basic principles: The individual frames and modules are already standardized, so you can customize your setup by adding components like side panels, new doors, or drawer inserts. Interior fittings with shelves, clothes rails, or drawer dividers are especially popular. Adding extra accessories such as storage baskets also helps optimize the interior space. It is important to measure the dimensions precisely before purchasing to ensure the new modules fit seamlessly. Ikea also recommends reinforcing the entire frame when adding wider sections—using the appropriate connector elements. If you want to increase the height of the system, suitable extensions are also available. Regarding doors, both sliding and traditional hinged doors are compatible, allowing very individual expansions. If you like, I can provide detailed information about specific components.
ladali
28 Jul 2020 12:08
katejo, "What options are available to flexibly expand the wardrobe with additional elements, accessories, or customizations without major effort," and "which components or system parts are particularly useful" – here is a structured overview: - Ikea Pax relies on modular frames with standardized widths (50cm (20 inches), 75cm (30 inches), 100cm (39 inches)) and heights. Extensions are usually made by adding more modules side by side or stacked. - Interior fittings such as shelves, clothing rails, drawers, pull-outs, and wire baskets are flexibly combinable and can be added or reorganized as needed at any time. - Door systems can be exchanged, and switching to sliding doors in particular facilitates space adjustments. - Complementary accessories like inner drawers with organizers, lighting, or a pull-down wardrobe lift increase functionality without rebuilding. - Use of corner connectors to join multiple modules ensures greater stability. It is important to pay attention to the maximum total weight when expanding. Also, do not forget wall mounting for stability. This way, the system remains mobile and flexible.
Josan
29 Jul 2020 08:37
ladali schrieb:
Ikea Pax relies on modular base frames with uniform widths (50cm (20 inches), 75cm (30 inches), 100cm (39 inches)) and heights.
Exactly, the entire system is based on this principle. Only in this way can new modules be easily added. Additionally: if you want to expand the wardrobe, it is always recommended to use custom interior fittings that are tailored to the frame width in order to make optimal use of the storage space. There are also solutions for increasing the height, for example by adding extra top frames, but the load limits must be observed. If needed, Ikea shelving systems (such as Kallax) can also be used alongside Pax to further increase flexibility.
rickey
30 Jul 2020 15:22
Hello everyone, I can easily understand how important a flexible expansion of the Pax system can be, especially when living situations change. I personally expanded my wardrobe step by step about a year ago and realized that it makes sense to consider future expansions from the start – for example, by ordering connecting elements or additional interior fittings right away. One idea I’d like to share: sometimes less is more. It’s better to focus on a few well-thought-out additions rather than buying every available accessory. This not only saves space but also prevents headaches during later rearrangements. My tip: when expanding, try out the new module in between to see if it really fits your needs before securing everything in place. This helps avoid frustrating fitting issues.
