ᐅ What is the best way to integrate Ikea Pax wardrobes into small bedrooms?
Created on: 8 Mar 2023 13:07
GESEMAN
GESEMAN
8 Mar 2023 13:07
Hello everyone, I am facing the challenge of fitting my Ikea Pax wardrobe as efficiently as possible into a relatively small bedroom. Since the Pax, due to its modular design and generous storage capacity, seems ideal, I am curious how others deal with spatial limitations. Specifically, I am interested in tips and experiences regarding the appropriate wardrobe depth, the best positioning within the room, wardrobe door design (e.g., sliding doors vs. hinged doors), and how to maintain as much free movement and openness in the space as possible despite the size of the Pax. Are there particular planning approaches or accessories that have proven especially useful in small bedrooms to keep the space functional and visually uncluttered? Thanks for all the advice and suggestions!
teyosef
8 Mar 2023 14:36
Hello GESEMAN, your question is very practical, and I’ll try to give a structured overview:
- Closet depth: For small bedrooms, I recommend the 35cm (14 inches) deep options, as they take up significantly less space than the standard depth of 58cm (23 inches) while still providing enough storage – ideal for clothes or shoes.
- Doors: Sliding doors are usually better in tight spaces than hinged doors because they don’t require swing space.
- Positioning: If possible, the wardrobe should be placed along a wall without windows to avoid blocking natural light and to help organize the room better.
Another tip: Use interior organization elements to efficiently utilize space in narrow wardrobes – for example, hanging rods at different heights, drawers, or shelves for smaller clothing items.
In summary: Opt for a compact depth, sliding doors, and smart interior fittings. Adding mirrors on the doors can also make the room appear more spacious. Hope this helps!
JORDON
8 Mar 2023 15:49
teyosef schrieb:
Sliding doors are usually better than hinged doors in tight spaces, as they don’t require any swing area.
I completely agree! Especially when space is limited, sliding doors are a real boon. Plus, using light colors and maybe a bit of small decorative touches can create a cozy, airy atmosphere.
My tip: Also consider corner solutions with Pax — they often provide more storage and fit quite well into small rooms if planned smartly. 😏
And don’t worry, installation isn’t that difficult if you carefully follow the instructions — that’s where I gained confidence and room for theory.
KARJU
8 Mar 2023 17:12
Practical experience and numerous tests show:
- A depth of 35 cm (14 inches) offers the best compromise between storage capacity and space efficiency in small bedrooms.
- Sliding doors avoid the need for clearance space when opening. However, it should be considered that interior space usage may need adjustment with internal drawers or shelves, as the back might become less accessible.
- Positioning: Ideally along a wall that does not block natural light and allows sufficient movement space (at least 60-70 cm (24-28 inches) in front of the wardrobe).
It is also recommended to integrate mirrored fronts. These have been proven to enhance the perception of space and replace a freestanding mirror, which would otherwise take up additional room.
Conclusion: Taking these points into account allows effective integration of Pax wardrobe modules into small bedrooms without visually or functionally overwhelming the space.
gojan7
8 Mar 2023 20:03
I would always choose the narrow option with a depth of 35cm (14 inches), plus sliding doors.
Place the wardrobe along the longest wall, if possible. This way, there is more room to move around.
GESEMAN
9 Mar 2023 09:21
KARJU schrieb:
These have been proven to enhance the sense of space and replace a separate standing mirror, which would otherwise take up room.
Thank you for the note about the mirror front. Do you think the integrated mirrors are sturdy enough for everyday use? Or in smaller rooms, would it be better to also add wall mirrors for improved light distribution? What has been the experience regarding maintenance and potential scratches on the mirrors of Pax doors? Are there any specific tips for preserving the surface?
