ᐅ How to Assemble IKEA Metod Cabinets in Older Apartments Without Causing Damage?
Created on: 11 Jun 2023 08:23
eljumanHello everyone,
I have a specific question: How can IKEA Metod kitchen cabinets and units be installed in older apartments without causing damage to the often fragile walls and floors?
Walls in older buildings are usually less stable than those in modern constructions; they are often made of old plaster or even cavity walls, sometimes with cracks or uneven surfaces. Simply screwing directly into the wall can easily lead to cracks or chipping.
I am particularly interested in practical experience and advice on how to carry out the installation safely: Are special anchors or different fastening techniques recommended? How do you deal with uneven floors that encourage misalignment of the cabinets? And what methods have proven effective to avoid damage while maintaining stability?
I look forward to your practical insights and possibly recommendations for tools or additional aids that can help during installation. Thanks in advance!
Hey eljuman,
great topic! I recently installed the Metod kitchen myself in an older building and had exactly the same concerns. The important thing is: don’t let it stress you out! 😊
To protect the walls, I definitely recommend using special hollow wall anchors or chemical anchors if the wall isn’t solid. These provide much better stability and distribute the load more evenly.
For the floor: definitely use adjustable feet from IKEA, so the cabinets won’t wobble and you won’t have to use force that could damage the floor!
And the most important advice: work in small steps and take your time adjusting everything. This prevents anything from breaking or chipping!
Good luck, you’ve got this! 😎
Hello eljuman,
your question touches on a crucial aspect of kitchen installation in older buildings. A secure setup without damage requires a thorough assessment of the specific structural conditions.
For old walls, which are often porous or crumbly, I recommend using only cavity or heavy-duty anchors. If possible, metal rails should be installed over a larger area to better distribute the load.
Also advisable is pre-drilling with the correct drill bit diameter and depth to avoid overloading the material. Including a safety margin to prevent possible cracks is important.
Regarding the floors, self-leveling feet are a good choice, as they can easily compensate for unevenness without causing the furniture to be crooked or putting stress on the wall.
Finally, especially with heavier components, it is better to rely on a second person to avoid sudden strain.
eljuman schrieb:
How can IKEA Metod kitchen cabinets and units be installed in older apartments without causing damage to the often delicate walls and floors?I always think people worry way too much about damaging old buildings. Sure, the plaster may not be the strongest, but with the right tools and some effort, it works fine.
Too often, people recommend a "gentle installation" that just means unnecessary extra work. Why not simply use the Metod wall brackets, securely screw them into the wall, and if needed, repair the plaster afterward? A kitchen is installed, not wrapped in cotton wool.
As for the floors: that only adds unnecessary complexity when spending ages trying to level everything perfectly. Sometimes it’s precisely the unevenness that gives the old building its charm – you just have to adapt the appearance accordingly!
What do you think?
I would like to clarify a few points to address this topic objectively.
How can the installation of IKEA Metod kitchens in older apartments be done without causing damage? Here are some targeted tips:
- Always check the wall condition before installation: old plaster, masonry, or cavity walls (e.g., stud walls) require different types of anchors.
- For solid old plaster: use heavy-duty anchors or universal metal anchors, but avoid standard plastic wall plugs.
- For cavity walls: use cavity anchors (toggle bolts) that expand behind the wall.
- Match the drill size to the anchor, use a rotary hammer drill, and drill only as deep as necessary.
- Attach the IKEA Metod kitchen wall brackets preferably to load-bearing parts of the wall (avoiding mounting over plaster cracks or joints).
- To compensate for uneven floors: use adjustable kitchen legs; IKEA offers compatible system parts for this.
- Before installation, disassemble the cabinets into individual parts and adjust them separately—this makes corrections easier.
It is also important to use the right tools effectively and work calmly and carefully to avoid even minor cracks or chipping. Good luck!
In addition to the previous explanations, I would like to clarify:
Older walls often have an uneven surface structure. A practical way to protect against damage is to use mounting rails (e.g., a longer metal strip attached to the wall), which are fixed at several points and bear most of the load from the kitchen cabinets.
This also allows for some flexibility in alignment and compensation for irregularities. The cabinets can then be attached to these rails using the IKEA wall brackets.
It is also advisable to prepare the wall by removing any loose plaster and, if necessary, treating it with a primer to prevent crumbling.
Furthermore, tension on wall fixings caused by uneven floors can be minimized if the cabinet carcasses stand on adjustable feet at the bottom, rather than being pushed upward against the wall.
This approach reduces both the risk of damage and the stress on the older wall.
