Years ago, I bought an IKEA Hemnes piece of furniture – specifically a chest of drawers – and although I have taken good care of it, it now looks somewhat worn. I would like to know how to make the IKEA Hemnes look like new again after years of use. What maintenance methods, repair techniques, or possibly special cleaning products are recommended to refresh the surface and wood texture? Are there any preventive measures that can help protect the furniture from aging faster? I appreciate any explanations and tips, as I want to preserve the piece as long as possible and avoid having to replace it.
A simple method to be sure: take a damp cloth and rub it on a less visible spot. If the wood shines slightly and does not absorb water, it is lacquered. With oil-finished or untreated wood, water tends to soak in and leave dark spots.
In addition, special wood care creams are available for lacquered surfaces that fill in small scratches and renew the lacquer layer without sanding.
As a general rule: regularly use a damp microfiber cloth for cleaning and avoid harsh chemicals or excessive water. This way, the paint finish lasts longer and the surface remains intact. For minor scratches, furniture wax can help; for larger areas, it is better to sand and repaint.
barsar schrieb:
Clear tip: If tape sticks firmly to the surface, it is painted. Thanks, that's a simple test idea—I will give it a try!
Are there any recommendations on how often such a surface should be repainted? I want to avoid having to redo it too frequently.
As a preventive measure, I recommend:
- Avoid direct sunlight to prevent fading
- Use coasters and placemats to avoid water stains or heat damage
- Do not place heavy or sharp-edged objects directly on the surface
This greatly extends its lifespan and keeps the appearance looking fresh for a long time.
