ᐅ How can Ikea Hemnes shelves be customized to create a unique look?
Created on: 14 Dec 2021 09:17
germanklo
germanklo
14 Dec 2021 09:17
Hello everyone, I am considering customizing my Ikea Hemnes shelves to make them look a bit more unique, as the standard design feels a little too plain for me. I am particularly interested in practical yet visually appealing ways to enhance the Hemnes shelves without much effort or causing any permanent damage. I am thinking of options such as painting the wooden surfaces, applying vinyl wraps or wallpaper inside the shelves, attaching handles, or adding other details. I’m also curious about how to manage these changes in the long term to maintain functionality and stability. What experiences do you have with this? Thanks in advance for your tips and advice!
naujon
14 Dec 2021 10:03
Hello germanklo, I find your project very interesting and would be happy to share some suggestions that I have tried myself. First of all: Hemnes shelves are mostly made of painted solid wood, which makes painting or applying adhesive films relatively straightforward if done carefully.
- Preparation: Lightly sand the surfaces with fine sandpaper to roughen the surface so that paint or adhesive film adheres better.
- Painting: Use high-quality wood paint, preferably water-based, so the finish is not too thick and the wood grain is not completely covered.
- Films and wallpapers: The inside surfaces of the shelves can be beautifully enhanced with self-adhesive films or fabric wallpapers. Applying a clear varnish on top helps to protect and make it more durable.
- Changing handles: Replacing the handles on Hemnes shelves with doors is an easy way to give the furniture a completely new look. There are many designs, ranging from modern to vintage.
One important tip: Avoid applying paint layers that are too thick or additional coatings that could interfere with opening or closing the doors. Also, when using adhesive films, make sure to seal the edges well to prevent peeling. If you have any more specific questions, feel free to ask!
SUPE2
14 Dec 2021 11:26
I have often used matte films; they look good and provide protection. Additionally, high-contrast colors inside always create a fresh appearance. Doors can be painted, which quickly gives a personal touch.
Dopoki
15 Dec 2021 14:45
naujon schrieb:
An important tip: avoid applying paint layers that are too thick or adding coatings afterward that could interfere with the opening or closing of the doors.
This is crucial. Hemnes shelves are precisely manufactured, and improper alterations can easily disrupt that.
Regarding design, I also recommend using shelves made of colored glass or acrylic. Although they require some effort, they clearly enhance the overall appearance.
Additionally, lighting systems—such as LED strips—inside the shelves can create accents, especially in open shelving units.
For a truly personalized touch, replacement back panels with wood decor options or printed boards can be installed. This requires craftsmanship and time but results in a unique piece.
However, I advise against making extensive modifications to the furniture to avoid voiding the warranty and compromising stability.
tinau
16 Dec 2021 09:18
As a complement to the previous tips: If you just want to add a small accent, self-adhesive metal or leather appliqués are a good option. They are relatively easy to apply and remove.
You can also visually enhance shelves by placing decorative items such as baskets or vases strategically, without altering the furniture itself.
If you want to use paint, I recommend chalk paint. It gives a particularly natural look on wood and can be well sealed with wax or clear varnish.
Roberta
17 Dec 2021 17:39
I painted my Hemnes shelves with simple brush strokes, which gives them a much more modern look. I also replaced the handles, which changes the appearance significantly.
