ᐅ How can Ikea Hemnes shelves be expanded or modified?
Created on: 20 Feb 2024 18:37
puga39
puga39
20 Feb 2024 18:37
Hello everyone, I have been using the IKEA Hemnes shelving unit for some time now and am generally satisfied with its quality and design. However, I want to expand or modify my shelves to better suit my living situation and needs. Specifically, I am interested in the best ways to modularly extend the Hemnes shelves—such as adding extra shelves, toppers, or side panels. Alternative modifications or custom adjustments to optimize storage space would also be of interest. What options are there if you want to adapt the Hemnes shelving not only functionally but also visually? Do you have experience with additional colors, surface treatments, or modifications like doors, drawers, or lighting? I look forward to concrete tips and various approaches to extend or alter the standard shelving unit. Thanks in advance!
narDietmar
20 Feb 2024 20:12
Basically, Hemnes shelves can be easily expanded modularly since the system is quite flexible. A common option is to add extra shelves, which IKEA offers as replacement parts, making it relatively simple to adjust the height of the compartments. This is especially useful for storing more smaller items and thus optimizing space usage.
puga39 schrieb:
What options are there if you want to adapt the Hemnes shelf not only functionally but also visually?
For aesthetics, painting or staining are good options if you have experience with wood treatments. It is recommended to sand very finely and use solvent-free paints to preserve the natural wood look. Adding decorative moldings to the visible edges or installing matching doors from the Hemnes range or third-party suppliers can also significantly change the furniture’s appearance.
Another functional option is to add accessories like drawer inserts or small LED lights that can be mounted on the inside surfaces. These installations should be done securely to avoid compromising the shelves’ durability.
CHENFAR
21 Feb 2024 09:46
There are several practical options available for expanding Hemnes shelves, which should be approached in a well-structured manner. One of the most important steps is to check the maximum load capacity of each shelf section; this information is usually found in the assembly instructions provided or can be requested directly from the manufacturer.
narDietmar schrieb:
Another functional option is add-on elements such as drawer inserts or small LED lights
Inserts and lighting not only increase convenience but can also significantly improve the functionality of the shelves. For customers who need more storage space or better compartmentalization, partitions or adjustable shelves are also suitable. It should be noted that the original materials from the Hemnes range offer the best compatibility.
Regarding visual changes, I recommend reversible surface treatments, such as removable films or magnetic paints, as these do not damage the material. Doors can be installed as needed, for example, simple glass or wooden doors, which are available separately. It is advisable to carefully consider exact measurements and weight before making such modifications, as any changes can affect the stability and usability.
KUDAISY
21 Feb 2024 14:53
If you want to meaningfully expand or modify your Hemnes shelf, I recommend a systematic approach. Here is a brief guide that might help you:
- Step 1: Material and Measurement Check
Make sure which shelf parts you have (height, width, number of shelves) and which IKEA accessories are compatible. The IKEA Hemnes system is fairly modular but not unlimited.
- Step 2: Expansion with Original Replacement Parts
Additional shelves can usually be purchased separately and installed using the original supports. Doors and drawers are also available to match. Important: Do not exceed the load capacity.
- Step 3: Conversion and Customization
- Install doors with soft-close hinges or glass doors
- Use inserts for drawers to improve interior organization
- Add LED lighting, ideally battery-powered and easy to attach
- Step 4: Visual Changes
Refresh shelves with light sanding followed by stain or wood varnish; mixing colors is also possible.
- Common mistake many people make: Applying paint layers that are too thick or having inconsistencies during preparation, which later cause peeling or uneven surfaces.
If you want, I can also provide the best sources for compatible accessories and check whether third-party suppliers offer good solutions.
