ᐅ How can IKEA Hemnes furniture be visually refreshed or redesigned?
Created on: 30 Jan 2017 08:42
jusidan
I am currently exploring ways to visually update IKEA Hemnes furniture without compromising its stability or functionality. I am especially interested in techniques that effectively and elegantly transform the classic white or wood-colored finishes.
Specifically, I am looking for ideas on surface treatments (e.g., painting, staining, applying films), combined techniques (such as adhesive films plus painting), or built-in modifications that can turn a Hemnes piece into a real eye-catcher – this could be a distinctive handle, a different style of baseboard, or a creative color scheme.
Does anyone have experience or tips on which materials work best with the MDF wood structure and how to avoid common beginner mistakes? I look forward to your suggestions!
bauku
31 Jan 2017 09:55
Wow, I love how a bit of paint and creativity can turn Hemnes furniture into completely new eye-catchers! I once covered the cabinet doors with wallpaper and then sealed them with a matte clear coat – it worked really well and gave the whole piece a lot of character!
The important thing is not to rush and to apply several thin layers instead. That way, the result comes out perfect!
Peone
1 Feb 2017 11:12
Regarding the topic of "visually updating," I would add that replacing the hardware can make a significant difference. Hemnes furniture often features simple, cozy handles that can be swapped for more modern or vintage alternatives.
You might also consider changing the furniture legs, for example by using higher metal feet to give the piece a lighter, more elevated look.
Those who prioritize sustainability should choose eco-friendly paints and materials, especially if there are children in the household.
TEBILO
2 Feb 2017 15:48
I would like to go into more detail here, as some aspects tend to be covered too superficially.
Hemnes furniture is mainly made of pine wood, MDF, and veneer. This means the following for processing:
- Sanding:
When working on the piece, be especially careful with veneered areas compared to solid wood, as you can easily damage the surface.
- When painting, you should follow these steps:
1. Sand raw with 120 grit
2. Remove dust thoroughly
3. Prime with an adhesion primer suitable for wood and MDF
4. Sand between coats with 220 grit after each layer of paint
5. Finally, apply 2-3 coats of water-based acrylic paint to optimally protect the surface
- Staining is more suitable for solid wood; with MDF, you should be cautious because it absorbs color differently. Also, sealing is always recommended after staining.
- For vinyl coverings, the surface must be completely smooth, grease-free, and even—any unevenness will show after applying the film. I also recommend doing the installation in a warm room to minimize bubble formation.
I’m curious which details you consider most important for the new design: Should the piece fit into an existing design concept, or are you aiming for a strong contrast?
jusidan
3 Feb 2017 10:19
TEBILO schrieb:
I’m curious to know which details you prioritize most in the new design: Should the piece of furniture fit into an existing design concept, or do you want to create a strong contrast?
Thank you for the detailed response, Tebilo!
For me, both aspects actually matter: I want to refresh and modernize Hemnes furniture visually without completely breaking with the room’s overall concept. That means a subtle yet fresh look with more depth and character would be ideal.
That’s why I find the idea of combining different textures or finishes interesting. The contrast should be rather subtle to maintain the bright and welcoming atmosphere. I might experiment with slightly darker paint finishes on the base or handles to emphasize the clean lines without making them too dominant.
Therefore, I’m also interested in approaches for harmoniously combining different surface types, for example, matte and glossy areas, or wood grain and colored surfaces. Does anyone have practical tips or experience to share?
