ᐅ How can IKEA Hemnes furniture be visually refreshed or redesigned?
Created on: 30 Jan 2017 08:42
jusidan
jusidan
30 Jan 2017 08:42
I am currently exploring ways to visually update IKEA Hemnes furniture without compromising its stability or functionality. I am especially interested in techniques that effectively and elegantly transform the classic white or wood-colored finishes.
Specifically, I am looking for ideas on surface treatments (e.g., painting, staining, applying films), combined techniques (such as adhesive films plus painting), or built-in modifications that can turn a Hemnes piece into a real eye-catcher – this could be a distinctive handle, a different style of baseboard, or a creative color scheme.
Does anyone have experience or tips on which materials work best with the MDF wood structure and how to avoid common beginner mistakes? I look forward to your suggestions!
Lyndon55
30 Jan 2017 10:07
Hello jusidan,
your question is very well formulated and, based on my experience with Ikea furniture, can be broken down into several steps. I will explain a possible process here that often leads to professional results:
- Preparation: Hemnes furniture is mostly made from solid pine with a paint or veneer finish. It is important to gently sand the surface (grit 180-220) to ensure that new paint or stain adheres better.
- Technique selection:
- Painting with water-based acrylic or acrylic lacquer works well as it has less odor and dries cleanly.
- Staining is an option if you want the original color to show through, but it requires a clear sealant as a final coat.
- Applying vinyl wraps or self-adhesive vinyl sheets allows for custom patterns, but you need to work very carefully to avoid bubbles.
- Design tips:
- Replacing handles with, for example, brass handles adds a high-quality look.
- Changing the baseboard height, for example by adding painted wooden strips, creates a visually lighter appearance.
- Mistakes to avoid:
- Insufficient sanding can cause peeling.
- Skipping priming may lead to stains.
In summary: Prepare the surface thoroughly, choose a method that fits your style, and finish with a protective clear coat.
Hope this helps!
blapau
30 Jan 2017 12:33
I would like to add that when painting Hemnes furniture, using a suitable primer is crucial. Without it, the new paint may not adhere well, as the pine wood components and MDF parts react differently.
It is also advisable to choose a matte rather than a glossy finish if you want to maintain the original country-style look while giving it a modern update.
Alternatively, lime-based or chalk paints are very popular for this series. They are easy to roughen up and can be sanded after the first coat to create a patina.
Deoren
30 Jan 2017 13:10
I have had good experiences painting furniture with chalk paint after sanding, followed by a clear varnish. This gives a matte, modern look and provides good protection.
REN40
30 Jan 2017 14:45
In addition to the mentioned techniques, I would like to suggest another option: wallpaper remnants or self-adhesive patterned films can be applied to individual surfaces. This gives the furniture a personalized touch and can be easily replaced or updated.
A tip: Do not cover the entire surface, but only specific areas, such as the back panels of shelves or cabinet doors. This creates a very modern look and draws attention.
KARMEO
31 Jan 2017 08:22
Try giving the Hemnes furniture piece a black color!
This looks very stylish and stands out from the usual white versions. Simply sand it well beforehand, then paint it, and finally apply a clear protective varnish.
