ᐅ How can IKEA Hemnes furniture be enhanced with LED lighting?
Created on: 8 Apr 2019 10:23
Ri_fe
Ri_fe
8 Apr 2019 10:23
Hello everyone, I have some furniture from the IKEA Hemnes series and I am considering how to best enhance it with LED lighting. I am not just looking for a simple light source, but I am thinking about whether it is possible to integrate suitable lighting into shelves, display cabinets, or under bed frames – discreet yet effective. It is important to me that this can be done with minimal modifications and that the solution is both visually appealing and functional. Maybe someone knows of suitable LED products or has practical ideas on how to best manage the power supply and mounting? Looking forward to your tips!
TEBILO
8 Apr 2019 14:11
Hello Ri_fe, your approach to enhancing Hemnes furniture with LED lighting is very well thought out. Basically, you should first consider whether to use battery-powered solutions or wired options—each has its own advantages and disadvantages. For shelves and display cabinets, LED strips with a 12V transformer work very well and can be attached using clips or double-sided tape. An important point is to keep cable management discreet. Thin LED profiles that emit low heat can be installed under bed frames. Pay attention to the color temperature; warm white (2700 to 3000 Kelvin) is more comfortable in sleeping areas than cool white. For power supply, I recommend using flexible extension cables or quick connectors. Have you already modified the furniture individually, or are they all still original? That way, I can provide more targeted advice regarding possible drilling or hidden cable routing.
LENNAU
8 Apr 2019 15:07
Hello Ri_fe, it’s great that you’re giving so much thought to the possibilities of LED lighting. If you don’t have much experience yet, I would recommend starting by experimenting with battery-powered LED strips or light strips. These can be easily stuck on and removed without much effort if you don’t like them. The Hemnes furniture is made of wood, which makes installation simple without damaging the surface. For connecting to the power outlet, there are also flat power supplies that can discreetly hide behind furniture. Dimmable LEDs also make a lot of sense to adjust the lighting atmosphere. If you like, I can gladly explain more about the advantages and disadvantages of the different systems.
kloreo
8 Apr 2019 16:42
LED strips with 3M adhesive tape are great for Hemnes shelves. Simply attach them, connect to a power supply, and you're done. For the underside of beds, use slim profiles for a refined look.
O
ottilie
8 Apr 2019 17:58
It’s interesting how often people screw LEDs onto furniture that isn’t even designed for electrical installations. I think Hemnes should stay Hemnes – adding individual lights quickly turns it into an overloaded sea of sofas. Why not opt for lamps or indirect lighting in the room instead of on every shelf? LEDs in furniture can be dismissed as a trendy gimmick rather than creating a genuine living atmosphere.
TEBILO
9 Apr 2019 09:21
ottilie schrieb:
Why not just use lamps or indirect lighting in the room instead of at every shelf?
That’s certainly a valid perspective, but not everyone wants to rearrange the entire living room. LEDs integrated into Hemnes furniture can provide targeted lighting in often overlooked spots, such as inside display cabinets for decorative items, which indirect ceiling lighting cannot achieve. Additionally, built-in lighting in furniture is often more energy-efficient and creates a pleasant localized atmosphere.
What I still consider important is planning before installation. Otherwise, it quickly becomes messy with cables and excessive lighting.
