ᐅ How can IKEA Hemnes furniture be temporarily repaired?
Created on: 4 May 2018 08:12
miramar
miramar
4 May 2018 08:12
I am looking for effective ways to temporarily repair IKEA Hemnes furniture. Specifically, it concerns minor damages such as loose screws, worn edges, or small cracks in wooden parts. The furniture should remain as stable as possible until I can carry out a permanent repair or replacement.
Does anyone have practical tips for quick fixes that require minimal tools or special materials? Any advice on specific adhesives or techniques suitable for the Hemnes series would be greatly appreciated.
Thank you in advance!
FIKAPU
4 May 2018 08:47
Hello, simply tighten loose screws with a suitable screwdriver.
For small cracks, wood glue works well and provides relatively quick adhesion.
Frayed edges can be carefully smoothed with fine sandpaper.
Teonon
4 May 2018 09:33
Great that you want to take care of it! 🙂
I fixed the loose back panels on my Hemnes bookshelf with small nails – works well until the proper repair.
Glue like Ponal is excellent for securing cracked areas. Just apply some glue, clamp it, and let it dry thoroughly. You can do it!
miramar
4 May 2018 10:29
FIKAPU schrieb:
Wood glue works well for small cracks, as it provides relatively quick adhesion.
Thanks for the tip! Which type of wood glue would you recommend? I've heard that some glues are water-resistant and better suited for furniture than others.
FREDRICK
4 May 2018 14:18
Regarding the choice of wood glue: Photovoltaic panel adhesive works well for indoor furniture, is easy to apply, and dries clear. For furniture exposed to higher moisture levels, I recommend using D3 or D4 classified glues, which are more water-resistant.
For Hemnes furniture, which is mainly used in dry rooms, a standard photovoltaic panel adhesive is completely sufficient. It is also important that the surfaces to be glued are clean, dust-free, and well clamped to ensure optimal adhesion.
nofomu
4 May 2018 19:52
For temporary repairs, I have often used wood filler when there were small holes or dents. After drying, sand it lightly, and it looks good.
This holds up reasonably well until a better solution can be implemented.
