ᐅ How can Ikea Hemnes furniture be repaired in a sustainable way?
Created on: 30 Dec 2023 08:13
leon1
A few years ago, I bought some furniture from the Ikea Hemnes series, which I really like both in terms of design and quality. Unfortunately, some pieces are now showing typical signs of wear, such as scratches in the finish, small dents in the solid wood, as well as a few loose screws or slightly wobbly joints.
My question to you is: How can Ikea Hemnes furniture be repaired sustainably without having to sand down or repaint the entire surface? I am looking for methods that are as simple and resource-efficient as possible—ideally using materials that are easy to find and that match the typical Hemnes finishes. If anyone has tips on maintenance, repair products, or specific techniques, I would be very grateful!
Dilen
31 Dec 2023 07:51
leon1 schrieb:
So far, I have mostly avoided sanding, fearing it might damage the paint even more.
That makes sense, especially with paint where detailed work is crucial and aggressive sanding can do more harm than good.
Regarding the drawer slides: for lasting cleaning, I would first remove them and clean with mild soapy water. Avoid oily or harsh chemical sprays. Afterwards, you can gently rub the slides with beeswax or a pure, solid plant-based wax – this creates a smooth surface that helps your drawer glide better without needing chemical lubricants.
Concerning the white spots on the edges: colored pencils work well if you find an exact matching shade. It is important to seal the pencil marks afterward with clear furniture wax to prevent the color from rubbing off quickly. Otherwise, you will notice differences after some time. Alternatively, repairable wax sticks can also be used here, allowing you to mix dark or light tones.
Timofa
31 Dec 2023 08:33
Sounds like you're already on the right track! If you like, you can try using a mixture of wax and a touch of vanilla extract on the drawer – it’s said to help everything smell nice and glide smoothly, without any harsh chemicals. 😄
When touching up with pens, focus on applying gentle, thin layers rather than thick ones, as thick layers can quickly look "painted on." Patience really pays off here.
GALENKU
31 Dec 2023 10:02
Remove drawer slides, clean them, and treat with beeswax. Touch up paint wear with matching furniture markers and reseal.
benon
1 Jan 2024 13:29
By the way: If you want to protect the paint without completely sanding it down, you can also apply clear coat spray selectively in small areas. However, this requires some practice to avoid unsightly edges.
Do you have access to a small spray brush or airbrush? This makes fine work much easier and allows you to achieve visually invisible repairs.
Dilen
2 Jan 2024 09:14
This is a very good recommendation for minor paint damage. It is important to lightly roughen the surface before application (for example, with 600-grit sanding fleece) to improve adhesion. However, please work carefully to avoid overspray on surrounding areas.
For a more lasting repair, I would also recommend testing how the paint reacts before applying any treatments. Sometimes a thin layer of water-based clear coat can work better, especially on open wood pores, as it is less toxic and more environmentally friendly.
mauka
2 Jan 2024 11:47
I actually find repairing Hemnes furniture really enjoyable – and with the right little tricks, the pieces almost look like new! My favorite are definitely the wax sticks, because they let you quickly touch up small scratches.
I also like to finish by rubbing a soft cloth with some beeswax over the surface – it smells nice and makes the finish pleasantly smooth. ?
As for the drawers: just try using the wax and, if needed, buff a little more afterward; it works really well.
