ᐅ How can IKEA Hemnes furniture be refreshed after several years?
Created on: 16 Aug 2021 10:22
Gigulen
Gigulen
16 Aug 2021 10:22
I have a somewhat specific question about furniture care and restoration that might interest some of you: How can IKEA Hemnes furniture pieces, which have been used for years and are now showing signs of aging, be effectively refreshed or improved?
Specifically, I am interested in suitable steps to repair scratches, dull surfaces, minor wear marks, or color changes without having to replace the furniture. It would also be important to know if there are recommended methods that are good for the wood and can visually enhance the furniture, whether through sanding, painting, oiling, or other techniques that are particularly effective for the Hemnes series.
Additionally, it would be helpful to know which products and materials to use to ensure the results are as durable as possible while preserving the character of the Hemnes furniture.
I look forward to your experiences and tips!
Grace
16 Aug 2021 12:35
Hello Gigulen,
I think your question about refinishing IKEA Hemnes furniture is very good and important, as these pieces are often made from solid wood types like pine, which offers several options for renovation.
First of all, it’s important to assess the condition of the furniture. If there are only minor scratches and dull spots, special furniture waxes or wood oils can often achieve a lot. For example, hard oil or natural oil can be applied after lightly cleaning the surface to improve wood protection and finish.
For more significant wear or discoloration, sanding can be useful. Since Hemnes is usually made of solid pine wood, the surface can be cleaned well before sanding, then sanded with sandpaper in different grits (e.g., 120 to 240) to prepare an even surface.
After sanding, proper after-treatment is very important: either with hard oil or a suitable water-based varnish. Water-based varnishes are more environmentally friendly and dry faster.
Preparation is also crucial: the surface should be dust-free and dry before applying oil or varnish to ensure a good bond. For ongoing care, I recommend furniture oil or special wood care oils that can be applied regularly to protect and maintain the wood’s appearance.
I hope this helps you already! If you need details on sanding or specific products, feel free to ask.
benfa
16 Aug 2021 14:47
Grace schrieb:
Since Hemnes is usually made of solid pine wood, the surface can be thoroughly cleaned before sanding and then worked with sandpaper of various grits (e.g., 120 to 240) to prepare the surface evenly.
Grace is correct that sanding is essential, but I would add that the choice of method should also consider the value of the piece of furniture. While Hemnes is relatively durable, it is not necessarily a high-end antique. Therefore, the question is whether the effort of completely sanding and refinishing is justified compared to the original purchase price.
It is also possible to achieve a significant visual improvement through spot restoration, such as using liquid furniture polish and small repair kits for wood dents. Furthermore, when it comes to finishing, an important aspect is the durability and toxicity of the products—especially for furniture used in living spaces, it is advisable to choose low-emission and sustainable lacquers and oils.
Personally, I also see this as an opportunity to give the piece a new character with alternative colors—for example, using white or gray wood lacquer. This can highlight the vintage charm of the Hemnes series and is a sustainable alternative to buying new. Of course, it’s important to know your sanding and finishing skills—mistakes often lead to unsightly results that can significantly reduce the value.
KAMERON
17 Aug 2021 09:18
benfa schrieb:
Personally, I also see this as an opportunity to give the piece of furniture a new character with an alternative color scheme – for example, with a white or gray wood paint.
Benfa makes an important point here: Hemnes furniture is ideal for restoration work due to its solid construction. Here are some clear recommendations based on my research and experience:
- Cleaning: Start with a mild cleaning agent to remove dirt and grease from the surface.
- Sanding: Use 120-grit sandpaper for rough uneven areas, followed by 220 to 240 grit for a smooth finish.
- Surface treatment: Depending on your preference, a transparent hard oil can be applied, which penetrates and preserves the natural wood texture. For more coverage and protection, a water-based acrylic paint is recommended.
- Color change: Before applying a new color, the old paint or oil layer should be completely removed to ensure proper adhesion.
- Drying times: Be sure to follow the specified drying times to guarantee optimal quality and durability.
The right method depends largely on the initial condition of the furniture and your preference for a natural or glossy finish. It is important to work in well-ventilated spaces and to use protective clothing in all cases.
Overall, I can say that the Hemnes series is very suitable for renovation and relatively easy to work on.
gauvin37
17 Aug 2021 18:03
The best approach:
- Thoroughly clean the furniture
- Sand down minor damages
- Use care oil or water-based varnish
- For more severe damages, sand completely and refinish
This is how most people do it; it’s simple and not too expensive. Hemnes holds up well to this.
