ᐅ How can IKEA Hemnes furniture be redesigned after several years of use?
Created on: 15 Jan 2020 09:34
kaleron
kaleron
15 Jan 2020 09:34
I am currently exploring ways to creatively and effectively redesign IKEA Hemnes furniture, which has been in use for several years, to avoid simply discarding or just covering it up. My question is: What options are available to visually and functionally enhance or transform existing Hemnes furniture after years of use without having to replace it entirely?
I am specifically interested in methods such as painting, altering the structure, or adding new components to achieve a modern look or modified functionality. Which materials, techniques, and designs are particularly suitable for renovating Hemnes furniture?
I would also appreciate tips on surface preparation, sustainable approaches, and experiences with durable modifications. Looking forward to your ideas and practical suggestions!
JAMESONB41
15 Jan 2020 10:02
The easiest way is to sand the furniture down and then repaint it with a water-based paint. Hemnes is made of real wood and accepts paint well. Replacing the handles can also make a big difference.
draleo
15 Jan 2020 12:47
For remodeling Hemnes furniture, a thorough surface treatment is primarily recommended, which includes the following steps:
- Removing old paint layers by sanding or chemical stripping
- Applying wood primer to secure the new coating and even out surface imperfections
- Using high-quality acrylic or chalk paints that are durable and long-lasting
Additionally, fitting modern or customized handles can significantly enhance the appearance. For functional modifications, retrofitted interior organizers such as shelves or drawer inserts are suitable to optimize storage space. Sustainability can be achieved with natural varnishes or paints that are solvent-free.
It should be noted that Hemnes, due to its pine wood base, is relatively soft, requiring careful finesse work to avoid damage.
Natan
16 Jan 2020 08:18
draleo schrieb:
It should be noted that Hemnes, due to its pine wood base, is quite soft, which requires careful handling to avoid damage.
This information is important because the material is often underestimated. However, I am wondering if modern veneers or decorative films could be used to completely change the surface without needing a lot of sanding or painting.
Aside from that, I am skeptical whether simple paints really extend the furniture’s lifespan in the long run. Especially for pieces subjected to heavy use, it might be beneficial to enhance the furniture with new materials such as metal appliqués or other elements to break up the classic Hemnes look. What do you think about these hybrid solutions?
Garry
17 Jan 2020 14:39
Natan schrieb:
I’m wondering if modern veneers or decorative films could be used to completely change the surface without much sanding or painting?
Yes, that is actually a good option. High-quality films today offer a wide range of design choices, from wood finishes to unique textures. They are relatively easy to apply and protect the furniture surface.
However, a smooth and clean base surface is always recommended to ensure good adhesion. For older Hemnes furniture, this might only require light sanding to remove unevenness.
Combining film application with new hardware often results in a fresh and modern look. It is important to use high-quality films, as cheaper versions tend to blister or peel off after a short time.
