ᐅ How can Ikea HEMNES furniture be protected from sunlight exposure?
Created on: 2 Feb 2023 08:17
motan
I recently purchased several pieces of furniture from Ikea’s Hemnes series. Since these items are mostly made of solid wood and have a light, usually white-painted surface, I’m concerned about potential damage from direct sunlight. Especially in my living room, which has large south-facing windows, UV rays could cause discoloration, yellowing, and drying out of the wood.
I’m interested in what measures you would recommend to effectively protect the Hemnes furniture from sun exposure without compromising the overall look of the room with heavy curtains or covers. Specifically, which materials or products are suitable, what alternatives exist regarding room climate or furniture care, and what general precautions should be taken to preserve the longevity and appearance of these pieces over time?
I’m grateful for any tips, suggestions, and experiences you can share!
motan
3 Feb 2023 08:13
JAFUHAU schrieb:
Maybe not a high-tech solution, but it works well and doesn’t take up too much space or reduce the brightness around the furniture.
That’s an important point, thank you! I also care about a cozy atmosphere, so heavy blackout treatments are definitely not an option.
Could you also share how often furniture needs maintenance when placed near windows? I want to avoid both under- and over-maintaining. Are there any recommendations specifically for painted Hemnes surfaces?
Ianlau
3 Feb 2023 09:05
motan schrieb:
Could you maybe also say how often furniture should actually be maintained when it is placed near windows?
If the furniture is exposed to sunlight, I recommend maintenance approximately every 3-4 months, even if there is no visible damage. This helps keep the protective layer intact and prevents small microcracks in the finish. With less light or no direct sunlight, maintenance every six months may be sufficient.
Use suitable waxes or polishes that do not contain harsh chemicals to avoid damaging the finished surface.
theota
3 Feb 2023 10:17
ianlau schrieb:
Use suitable waxes or polishes that do not contain harsh chemicals, to avoid damaging the paint surface.
Or even better: just avoid it and move the furniture a bit away from the window. Most care products are usually just placebo. If you use the room properly, you don’t have to worry about the sun.
pikin
3 Feb 2023 11:44
theota schrieb:
Or even better: just leave it and move the furniture a bit away from the window.
There is a lot of truth in that. Physical measures, such as minimizing direct sunlight on furniture, have the most significant impact on preserving the surface.
Care products only support and extend the lifespan but do not replace direct protection from UV radiation.
anken
4 Feb 2023 08:53
Finally, I would like to add one more thought: stabilizing room temperature and humidity is also crucial for wooden furniture. Especially in heated rooms with large window areas, drying caused by sunlight and dry air can put additional stress on the wood.
A humidifier in winter or regular ventilation can make a difference here and prevent cracks or warping.
JAFUHAU
4 Feb 2023 10:07
anken schrieb:
Stabilizing room temperature and humidity is also crucial for wooden furniture.
I fully agree. The focus should not only be on direct sun protection but on maintaining the overall indoor climate. Furniture care and protective measures are effective only if the surrounding environment is appropriate.
