ᐅ How can IKEA Hemnes furniture be protected from damage using felt and cork?
Created on: 24 May 2021 14:07
rome69Hello everyone,
Some time ago, I purchased several pieces of furniture from the IKEA Hemnes series, which are known to be made of solid pine or sometimes combined with MDF panels. Since I don’t use rugs in my apartment and mostly have hard floors, I am concerned about the long-term protection of the furniture surfaces and feet. Specifically, I am interested in ways to effectively protect Hemnes furniture with felt or cork from unsightly scratches, pressure marks, or other damage—both on the furniture feet that have direct contact with the floor and on the surfaces when placing glasses or other objects on them.
Perhaps someone has experience with suitable felt or cork pads whose adhesive is not too strong or that can be removed without leaving residues? What is the best way to attach them without damaging the sustainable materials of the furniture? Alternatively, are there specific brands or product types that work particularly well for Hemnes furniture?
I look forward to your practical tips and any recommendations to keep my furniture in good condition for the long term. Thanks in advance!
Hello rome69,
I completely understand your concerns, especially regarding the rather light and delicate wood surfaces of the Hemnes furniture. Materials like felt and cork are indeed very suitable for protecting both feet and surfaces because they are flexible and gentle.
Regarding felt pads: I recommend using very thin, self-adhesive felt gliders made from 100% wool felt. These are sturdy enough to prevent scratches caused by movement, and the adhesive is usually acrylic-based, so it can be removed without damage if you need to replace them. However, it is advisable to thoroughly clean and degrease the surface before application, for example with isopropanol, to ensure the pads adhere properly and do not slip.
With cork, it is a bit trickier, as pure cork pads with adhesive are less common. Often, cork is combined with a layer of adhesive and backing material. Adhesion works best when the furniture is not subjected to heavy load. Alternatively, small cork pieces can be fixed with thicker double-sided tape. It is important to regularly check the surface and replace the pads if worn, as cork can swell when exposed to moisture.
Additionally, I recommend not placing gliders only at single points but covering as much of the surface as possible to avoid pressure marks. This is especially important for heavy pieces of furniture from the Hemnes series.
On the subject of surface protection: For glasses and vases, you can arrange thin cork or felt coasters vertically or use larger plates as covers – but make sure they can be removed without leaving residue or causing discoloration.
I hope this helps! If you have any questions about specific products, feel free to ask again.
farGlen schrieb:
I always use small felt pads from a well-known hardware store for Hemnes furniture. Just peel them off and stick them on. They have lasted for years without any problems and protect both the floor and the furniture well.I completely agree, but I would add that it is important to use felt and adhesive of good quality. Cheap pads often have glue that becomes brittle over time or leaves residue.
You should also regularly check that the pads are still firmly attached. If they start to come loose, they can easily cause scratches on the hardened undersides when moving the furniture.
For surfaces under glasses, you can also use special felt pads or thin cork sheets. Here, too, careful adhesion is worthwhile to prevent slipping and moisture penetration. Important: Hemnes furniture often has a painted finish that can be damaged by aggressive adhesives or prolonged moisture exposure. Therefore, be cautious with products containing viscous glue or those not specifically designed for delicate wood surfaces.
Occasional gentle cleaning of the protective pads and furniture surfaces can also help prevent dirt or moisture buildup. A combination of cork and felt can work well when applied appropriately in different areas.
