I’m planning to childproof some IKEA Hemnes furniture in our children’s room. My main focus is on typical safety aspects such as securing small parts, preventing tipping, and locking drawers to avoid unintended opening. I’m wondering about practical modifications that don’t significantly compromise the furniture’s aesthetics or functionality.
Does anyone have experience with making the Hemnes dresser or wardrobe more stable, and which child safety devices can be integrated effectively? I’m interested in all tips, from simple adjustments to more extensive modifications.
Thank you!
Thank you!
First, regarding stability: IKEA Hemnes furniture is generally designed for normal use but does not come with special anti-tip devices installed from the factory. To prevent tipping, I recommend:
- Using wall brackets or anti-tip restraints specifically designed for furniture, which can be discreetly attached behind the piece.
- Securing the furniture to the wall whenever possible, especially for tall dressers where there is a risk of tipping.
For drawer closing, there are child safety locks that are mounted inside and invisible from the outside. Examples include latch locks or magnetic locks. It is important that these are securely installed and not easy to release.
Another option is removing the drawer handles to make access more difficult, if functionality allows.
Make sure to regularly check all screws to maintain stability.
V
valerie-tr29 Nov 2018 06:14I would like to add some details:
Solid wood Hemnes furniture is sturdy, but the cabinets tend to be relatively tall and narrow, which often limits their stability against tipping. My advice is to proceed systematically:
- Step 1: Before installing any anti-tip devices, be sure to check whether the wall type (drywall, concrete, etc.) can support the load from the safety anchor. For drywall, consider using specialized anchors.
- Step 2: For drawers and doors, I recommend latch locks with magnetic mechanisms, as they remain hidden and are child-safe. Examples include "KidCo" styles or IKEA’s own versions. Important: Use two locks per wide drawer for better security.
- Step 3: To prevent small fingers from getting caught in gaps, self-adhesive edge protectors or silicone strips can be helpful.
- Step 4: For small items inside the furniture, it’s advisable to store them in lockable boxes or secure them with child locks to prevent unauthorized access.
A question: How old is your child, or how active are they? This will help to recommend the safety measures more precisely.
valerie-tr schrieb:
One question: How old is your child, or how strong is their urge to move around? This helps to recommend safety measures more precisely.Thank you for the very helpful tips! My child is just under 2 years old and very curious, also very active physically – especially climbing and pulling things. That’s why the solution needs to be very sturdy; I don’t think simple magnetic locks will always hold.
FABIAN_DEO29 Nov 2018 15:37At the age of 2 years, as glami describes, there is indeed a high demand for robust safety measures.
I recommend the following approach for Hemnes furniture:
- Wall attachment: Use sturdy metal brackets or custom anti-tip devices that can be screwed either behind the dresser or mounted to the wall. Make sure they cannot be easily loosened.
- Drawers and doors: Instead of simple magnetic catches, you can retrofit automatic soft-close systems that prevent drawers from opening on their own. Alternatively, bolt locks with key functions are recommended.
- Edge protection: As already mentioned, but especially attach it to the lower areas to prevent bumps.
- Additionally: For particularly curious children, installing an extra locking system inside the furniture that is not easily visible from the outside is worthwhile.
Have you checked whether the furniture is resting on shelving boards or floor coverings? This can additionally affect tip stability.
Good morning,
I would like to support the previous posts and point out that a simple but effective measure is often underestimated:
- Increase the furniture’s slip resistance, for example by using anti-slip pads under the feet. This reduces small movements that can cause tipping.
- Also, all screws, handles, and edges should be checked regularly and tightened if necessary. Children often test stability by pulling.
- If you want to implement toddler safety for drawers easily, there are so-called "Grip-Lock" locks that are quick to install and don’t require major modifications.
I think it’s important to stay patient and regularly adjust safety measures according to the child’s stage of development.
