Hello everyone, I am currently planning to furnish the children’s room with IKEA Hemnes furniture but want to make sure the setup is truly child-safe. I really like the look of the Hemnes series, but it does have some sharp edges and furniture with drawers and doors that could potentially pose risks for small children.
I’m particularly interested in which specific measures are recommended to make the Hemnes furniture child-safe. I’m thinking of practical protections like edge guards, special locks for drawers and doors, secure wall mounting, as well as possible custom modifications. Of course, I want to keep the functionality and aesthetics of the furniture as intact as possible.
Does anyone have experience with childproofing the Hemnes range or know of especially effective products or methods to make these pieces safer for toddlers without too much effort? I would appreciate detailed tips, including advice on common hazards with Hemnes furniture and the best ways to mitigate them.
Hello ayazkar,
Regarding your concern: The Hemnes furniture is sturdy and visually appealing, but due to its angular design and the use of drawers, it is not completely childproof without additional safety measures.
I will go through the most important precautions step by step:
- Wall anchoring: In my opinion, this is the most important measure. Hemnes dressers and tall cabinets are heavy and can easily tip over if children pull on them. IKEA provides mounting hardware, but check yourself if the screws and anchors are suitable for your wall. It may be advisable to upgrade to stronger anchors if necessary.
- Edge protection: The corners of Hemnes furniture are quite sharp. For tables and cabinets alike, I recommend soft edge protectors that are easy to apply and provide impact cushioning.
- Drawer and door locks: For drawers and cabinet doors, either self-adhesive magnetic locks or mechanical child safety locks that are visibly attached work well. Magnetic systems are often more aesthetically pleasing and easier for adults to operate, but make sure they are strong enough to deter curious toddlers.
- Drawer depth and weight: Since Hemnes often features solid wood fronts, the drawers can be quite heavy. If a child pulls a drawer completely out, there is a tipping risk. There are special drawer slides with stoppers available to prevent this.
- Avoiding small parts: Make sure no small pieces can come loose from the furniture, such as handles or screws, which a child could swallow.
I would also be interested to know how old your children are and which specific Hemnes furniture pieces you plan to use. Children of different ages pose different challenges.
If you like, you can also mention how much effort and what budget you consider acceptable for safety measures.
Out of interest, I would like to offer a critical perspective. Protective measures like edge guards or child safety locks for drawers are often recommended, but are the Hemnes furniture pieces really suitable for children’s rooms?
IKEA itself does not provide specific safety guarantees for this series, as it was not originally designed specifically as children's furniture. In my opinion, the purchase of Hemnes furniture for a child’s room should be carefully reconsidered, and it is better to opt for furniture that has been specially tested for children. Dimensions, material properties, and construction all play a role when you want to furnish a room in a truly child-friendly and safe way.
Therefore, I recommend considering the above before investing a lot of effort into retrofitting. Not only safety aspects are important but also ergonomics and the way children use furniture, which are not taken into account in the Hemnes design.
Those who still want to use Hemnes should understand this as a conscious compromise and take consistent safety measures accordingly.
I would be interested to know how others here evaluate the compromise between appearance and safety in this furniture series.
Hello ayazkar,
I completely understand your concerns. Especially with small children, the risks related to furniture should not be underestimated. I also used Hemnes in a children’s room, and the following measures really helped us:
- In addition to securing the furniture to the wall, we used drawer locks – these prevent the little ones from pulling the drawers out completely.
- All corners and edges were covered with transparent, soft edge protectors.
- We installed safety latches on the doors so they cannot be opened easily.
It is important to apply these measures consistently, as children quickly learn where the weak points are. You should also regularly check that the safety devices are still firmly in place.
I also made sure that no small decorative items were left on the furniture to minimize risk factors.
If you like, I can send you a list of the materials we used – they are mostly affordable and easy to install.
ayazkar schrieb:
I really like the Hemnes series in terms of design, but it does have several sharp edges as well as furniture with drawers and doors that could potentially pose risks for small children.That’s exactly the key point. Aesthetics and child safety often need to be balanced against each other. Hemnes is very popular, but you can’t automatically assume it is child-safe furniture.
Tevin schrieb:
All corners and edges were covered with transparent, soft edge protectors.I recommend that too—it’s possible to get very discreet protective profiles that hardly affect the appearance. It’s also very important to use high-quality edge protectors that don’t fall off easily.
- Extremely critical are tall dressers and cabinets, which can only be considered reasonably child-safe if they are securely anchored to the wall.
- Drawer slides with soft-close or stop mechanisms are also a very good investment; however, Hemnes usually does not come with these features from the factory.
Finally, I’ll repeat your question: What age group is your child? This affects how urgent certain protective measures are.
