ᐅ How can Ikea Hemnes furniture be functionally expanded?
Created on: 30 Oct 2019 12:37
Marthetan5
Marthetan5
30 Oct 2019 12:37
I’d like to start right away with a specific question for the group: How can Ikea Hemnes furniture be functionally expanded without compromising its clean design line? I’m particularly interested in practical solutions to increase storage space, make the furniture more versatile, and at the same time preserve the durability and aesthetics of this series. What kinds of expansions are possible or have already been tested? Has anyone had experience with systems that work modularly as add-ons, such as top shelves, interchangeable components, or smart interior fittings? Suggestions that require minimal effort are especially welcome, as I prefer not to buy completely new pieces of furniture. Looking forward to your insights and ideas!
taudi
30 Oct 2019 14:16
This is an interesting topic that presents similar challenges for many people! Hemnes furniture is known for its classic, rather simple design and solid craftsmanship, which provides a good foundation for functional upgrades.
Here is a brief guide to enhance functionality:
- Add-on shelves or extra shelves: These can often be easily mounted with simple dowels and provide additional storage space upwards.
- Internal organization: Drawer dividers or small boxes help to better organize existing drawers.
- Casters under dressers or shelves: This makes the furniture mobile and allows it to be moved when needed, for example, for cleaning purposes or more flexible room layouts.
- Replaceable fronts: This requires some DIY skills but allows you to replace doors with glass fronts, making the furniture appear lighter and airier.
Common mistakes when upgrading include overloading the structure, which affects stability, or using inappropriate fasteners that damage the surface. Always follow the original assembly instructions and keep load limits in mind.
In summary, modular additions that attach to the existing structure are ideal for functionally expanding Hemnes furniture.
batabe
30 Oct 2019 16:04
I would like to revisit the topic of increasing storage space, as this is often the main reason for enhancing the functionality of furniture like the Hemnes series.
What I highly recommend is using smart interior fittings:
- Using adjustable drawer dividers made of wood or plastic that can be customized to fit your individual needs.
- Adding pull-out shelves or baskets that can be retrofitted, for example under shelves, to improve accessibility.
- Magnet strips or small hooks on the inside of doors for storing items like keys or small tools.
You should always pay attention to the weight of these additions, as overly heavy attachments could overload the furniture’s fixings.
Maybe you could also check if there are official or third-party furniture extensions specifically designed for Hemnes, since IKEA is generally quite open to modular complete solutions.
I would also be interested to know whether you want to expand furniture such as dressers, cabinets, or beds? That could help tailor the recommendations more precisely.
Marthetan5
31 Oct 2019 09:22
batabe schrieb:
I would also be interested to know if you are looking to extend furniture like dressers, cabinets, or beds?
That’s a very good point! Primarily, I am thinking of dressers and possibly the Hemnes TV bench model I have in my living room. I often find the surface area quite limited there, and the use of compartments could be optimized.
Beds could also be interesting, especially with practical built-in drawers under the frame to make better use of space. What I find lacking in the Hemnes range is a ‘plug-and-play’ concept for such extensions. I feel that the way these pieces are constructed makes it somewhat difficult to combine them independently.
Are there any ideas or insights about universally compatible modular extensions that can seamlessly integrate into the structure of this furniture without compromises? I am also open to DIY craft solutions, as long as they look good visually.
taudi
1 Nov 2019 07:53
Marthetan5 schrieb:
Are there any ideas or insights on universally compatible modular extensions that fit seamlessly into the structure of these pieces of furniture without compromises?
That’s an interesting question, aiming almost at a systematic solution for functional extensions.
In general: Hemnes furniture is based on a standardized grid system and screw fittings, which makes adding external modules easier.
A few proven recommendations:
- Extension sets with top shelves in the same wood finish are often available and provide additional storage without breaking the style.
- On the inside of doors, custom-cut shelves or hook strips can be attached by adhesive or screws without major modifications.
- Under beds, rolling drawer boxes can be placed – they are visually neutral and significantly increase usable space.
For those skilled in DIY, laminated wood panels can be cut to size and mounted with brackets in matching colors to enlarge storage areas. This works well if you stick to the original dimensions and keep the surface as undisturbed as possible.
My advice is: functional extensions should be reversible so that the furniture can be restored to its original condition at any time, preserving its value. This way, there is hardly any risk in modifying it.
