ᐅ How can IKEA Hemnes furniture be easily customized or upgraded?
Created on: 20 May 2022 16:37
Yannmau
Yannmau
20 May 2022 16:37
Hello everyone, I have some IKEA Hemnes furniture, and I would like to give it a bit of a "makeover" with minimal effort—improving its appearance and functionality without needing advanced DIY skills or spending a lot of money. I’m looking for simple, effective methods or ideas on how to make pieces like the Hemnes chest of drawers, sideboard, or wardrobe look more unique and higher quality through small adjustments or decorations. I am especially interested in how to treat surfaces, change handles, or apply other easy tricks that can be done without much experience. Does anyone have tips or personal experiences of what has worked well? Thanks in advance!
baAlejandr
20 May 2022 19:52
First, I recommend focusing on the handles, as these often give the Hemnes furniture series its typical IKEA look. Replacing them with more substantial or vintage-inspired metal handles can significantly enhance the appearance with little effort. Another simple option is to coat the surfaces with a matte clear lacquer to make the wood look more durable and refined. If you want to add some color, I suggest using a subtle accent color only on certain elements, such as the back panels of shelves or the insides of drawers.
Another idea is to place felt pads under the furniture feet to give the pieces a lighter feel and protect the floor. These small details often go unnoticed but contribute to the overall impression. It’s important that these modifications can be done with simple means and without the need for major tools.
bapar
21 May 2022 08:16
Yannmau schrieb:
I am looking for simple, effective methods or ideas to make furniture like the Hemnes dresser, sideboard, or wardrobe look much more unique and high-quality through small adjustments or decorations.
The Hemnes range is generally well-suited for upcycling since it is made of solid wood. The most important step is properly sanding the surfaces before applying new paint or stains. For a “small effort” project, I recommend using fine-grit sanding pads that can be used by hand. This way, you only remove the superficial paint layer and can create a new finish without damaging the furniture.
For coloring, I suggest chalk paint, as it can be applied without much preparation and dries with a matte finish—very popular for Scandinavian or rustic designs. Applying a clear protective topcoat will protect the surface during normal use.
If you want to change the handles, make sure the new ones match the existing drill holes exactly to avoid extra work. Alternative materials like leather or rope handles can give the furniture a special touch and are often very easy to attach.
One more tip regarding functionality: interior organizers or baskets made from natural materials can not only help structure your storage better but also visually enhance the charm of Hemnes furniture.
In closing: what tools do you have? Do you already own sandpaper or brushes? With the right tools, the effort can be kept very low.
derrick34
21 May 2022 11:43
Change the handles, lightly sand the surface, apply new paint or clear varnish. Done. This greatly improves the look. If you want it done quickly, just new handles are often enough.
LUISABEL
22 May 2022 14:29
baAlejandr schrieb:
Replacing them with more substantial or vintage-inspired metal handles can significantly enhance the look
This recommendation is very accurate. I would like to add that when choosing new handles, an important aspect is material quality: handles made of solid brass or stainless steel tend to wear less and look more valuable than plastic or injection-molded parts. The fastening method should also be sturdy to prevent any wobbling on the furniture.
Regarding surface treatment: using furniture wax instead of clear varnish is a simple way to give the wood a warm, matte finish while providing surface protection. Furniture wax can be applied with a soft cloth and does not require special tools.
In summary, I recommend the following straightforward steps:
- Prepare surfaces by sanding or lightly roughening
- Choose new handles with high-quality materials and suitable design
- Seal surfaces with furniture wax or varnish, depending on the desired effect
- Optional: use inserts made of natural materials for functional enhancement
With these steps, the Hemnes furniture becomes an individual highlight with minimal effort.
